nitrous tune? #477561
09/23/09 02:30 PM
09/23/09 02:30 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
if my fuel pressure problem is solved I plan to hit the new car with a 200hp shot for 2 secs. at sat. nite bracket race. It is 1/8mile and my best time on motor is 5.01
any guess as to what it will run on the NOS??
Re: nitrous tune? [Re: MegaDart] #477562
09/23/09 02:39 PM
09/23/09 02:39 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
How soon are you turning it on? What system plate of fogger? What tune-up (jet numbers)?
Re: nitrous tune? [Re: challenger1320] #477563
09/23/09 03:19 PM
09/23/09 03:19 PM
Renton Washington
Triple Threat Offline
Renton Washington
Depends on when you have it set to engage, its gonna make more of a difference if you're on the spray from the get go, rather than using it down track.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: nitrous tune? [Re: Triple Threat] #477564
09/23/09 04:05 PM
09/23/09 04:05 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
it is an NX plate system I will have to check my logbook but it is jetted for 200hp (41/62?). I am turning it on .01 out for 2 sec duration and will be pulling out 10deg of timing at the hit.
I feel this should be a very safe tune? Baby steps as it's been a long while since I played with NOS and I'm really not looking for huge gain.
Re: nitrous tune? [Re: MegaDart] #477565
09/23/09 04:19 PM
09/23/09 04:19 PM
Sidney,Ohio
Sidney,Ohio
Check the jetting something isn't right with those numbers if that is nos 41 / fuel 62 you are way way to fat. With a good tune-up, on at .1 for 2 sec should see around a .2 decrease in ET
Re: nitrous tune? [Re: challenger1320] #477566
09/23/09 04:23 PM
09/23/09 04:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and you haven't consulted with Monte why?
Re: nitrous tune? [Re: challenger1320] #477567
09/23/09 04:24 PM
09/23/09 04:24 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
ok just checked 57nos 41 fuel, I will be running 8psi fuel pressure.
.2 is exactly what I would like to see in the 1/8. Then I can chase me a few dragsters!
Re: nitrous tune? [Re: Quicktree] #477568
09/23/09 04:26 PM
09/23/09 04:26 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
because I just finished the install... actually it's not fully plumbed waiting for the big brown truck!!
Re: nitrous tune? [Re: MegaDart] #477569
09/23/09 04:27 PM
09/23/09 04:27 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Why 2 seconds? Seems a smaller shot for the entire run would be easier on things.
Re: nitrous tune? [Re: BobR] #477570
09/23/09 04:39 PM
09/23/09 04:39 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
I gotta start somewhere don't I? Looking for data and to stay very conservative. There is a method to my madness and an objective. That is to be dialed 7.50 in Rockingham next month with a little NOS as possible.
also, it is sat. nite bracket race and I will be lucky if the track will hold what I've got
advertised tuneups are usually pretty safe also to it may be more like 150hp. IMO, any less would be a waste of time.
Re: nitrous tune? [Re: MegaDart] #477571
09/23/09 04:58 PM
09/23/09 04:58 PM
Sidney,Ohio
Sidney,Ohio
Personaly I am with Bob on this I would spray a 125 shot from as close to 0 as possible and spray the whole run. I have a 73 Challenger at 3100 LBS with a 572 -1 motor in it runs 5.50's in the 1/8 with a 125 shot spraying from 0. 1.21 60 foots
Re: nitrous tune? [Re: challenger1320] #477572
09/23/09 06:05 PM
09/23/09 06:05 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
what's it run off the bottle?
it's funny, I never thought of a 200hp shot as being very large
Re: nitrous tune? [Re: MegaDart] #477573
09/23/09 06:18 PM
09/23/09 06:18 PM
Sidney,Ohio
Sidney,Ohio
5.80's
Re: nitrous tune? [Re: challenger1320] #477574
09/23/09 06:35 PM
09/23/09 06:35 PM
UK
602heavy Offline
602heavy  Offline
UK
I run the NX perimeter plate like the one you have , maybe set the FP @ 9 PSI , 10* is a good starting point , what fuel are you using? , these are great kits with a good jet spread out the box , i agree , hit it straight off the line.
Re: nitrous tune? [Re: 602heavy] #477575
09/23/09 07:28 PM
09/23/09 07:28 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
maximal
I'll stick with .01 off the line for now, at least for the first hit! will aid in the learning curve!!
Re: nitrous tune? [Re: challenger1320] #477576
09/24/09 09:55 AM
09/24/09 09:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
challenger1320 what type of chassis u running/rear end.Thax
Re: nitrous tune? [Re: racerx] #477577
09/24/09 10:00 AM
09/24/09 10:00 AM
Sidney,Ohio
Sidney,Ohio
Basic backhalved car with mild steel 8 point cage. Dana 60 with 4.10, 33/16.5 x 15 Goodyears
Re: nitrous tune? [Re: challenger1320] #477578
09/24/09 10:47 AM
09/24/09 10:47 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I allways looked at it from the torque gain not the hp , 200 shot down low makes for a lot of twist
Re: nitrous tune? [Re: MegaDart] #477579
09/24/09 12:49 PM
09/24/09 12:49 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
maximal
.01 off the brake is functionally the same as off of the brake. The .01 just gets the tires loaded before the unit hits. The part that I don't understand is why you would want to turn it off before the finish line.
Re: nitrous tune? [Re: BobR] #477580
09/24/09 01:35 PM
09/24/09 01:35 PM
The Swamp
MegaDart Offline OP
MegaDart  Offline OP
The Swamp
because I really don't like nitruous I just need to find .2 et. Looking to shut it off asap...
I would like to know why you and challenger think it is better to spray the entire run rather then the way I plan to do it?? I know quite a few guys that do it this way.
