Re: 70 Challenger wont start in park or reverse
[Re: SunburstKid]
#477227
09/23/09 11:58 AM
09/23/09 11:58 AM
Posts: 304 Ohio
LS-300
Ohio
If the car would crank and start with the key turned then shut off when you release the key, check the balast resistor.
1979 Chrysler 300
1968 Barracuda project
[Re: stumpy]
#477229
09/23/09 02:25 PM
09/23/09 02:25 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
OP – your thread title and your 1st post conflict a little, and for an electrical problem like this it’s easy to get the rest of us sidetracked if the specifics aren’t spot-on accurate.
LS-300 is correct on the ballast resistor clue, but I’d suspect the ignition switch also.
Neutral safety switch should only interact when cranking the starter motor, not at other times. If car will not start in park but will start in neutral then NS circuitry is to blame.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
