70 Challenger wont start in park or reverse #477224
09/23/09 03:44 AM
09/23/09 03:44 AM
San Diego, Ca,
SunburstKid Offline OP
San Diego, Ca,
70 Challenger column automatic sometimes will not start or run in park or reverse. Today It started in Park, then just died. Lights stayed on and it had electrical power. I got it started again then died while in reverse!
Where do I start?
Re: 70 Challenger wont start in park or reverse [Re: SunburstKid] #477225
09/23/09 05:32 AM
09/23/09 05:32 AM
abodyman Offline
super street
abodyman  Offline
super street
Start with the neutral safety switch!
loose wires, linkage etc...
Re: 70 Challenger wont start in park or reverse [Re: abodyman] #477226
09/23/09 11:35 AM
09/23/09 11:35 AM
San Diego, Ca,
San Diego, Ca,
Thanks I will check that out!
Re: 70 Challenger wont start in park or reverse [Re: SunburstKid] #477227
09/23/09 11:58 AM
09/23/09 11:58 AM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
If the car would crank and start with the key turned then shut off when you release the key, check the balast resistor.
1979 Chrysler 300 1968 Barracuda project
Re: 70 Challenger wont start in park or reverse [Re: LS-300] #477228
09/23/09 12:35 PM
09/23/09 12:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It shouldn't start in reverse. If it does then your shift linkage is out of adjustment. It should only start in Park and Neutral.
Re: 70 Challenger wont start in park or reverse [Re: stumpy] #477229
09/23/09 02:25 PM
09/23/09 02:25 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
OP – your thread title and your 1st post conflict a little, and for an electrical problem like this it’s easy to get the rest of us sidetracked if the specifics aren’t spot-on accurate.
LS-300 is correct on the ballast resistor clue, but I’d suspect the ignition switch also.
Neutral safety switch should only interact when cranking the starter motor, not at other times. If car will not start in park but will start in neutral then NS circuitry is to blame.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: 70 Challenger wont start in park or reverse [Re: Fury Fan] #477230
09/23/09 03:03 PM
09/23/09 03:03 PM
San Diego, Ca,
San Diego, Ca,
Ok it starts in Park sometimes. One time it just shut off while in park. Another time it did it in reverse. Everything is fine in drive.
Thanks again I appreciate the input!
Re: 70 Challenger wont start in park or reverse [Re: SunburstKid] #477231
09/23/09 03:52 PM
09/23/09 03:52 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If it only starts in PARK some of the time, it's probably a linkage problem. My Challenger did that and the linkage was all worn where it goes through the floor and pivots in the bushing. Sometimes it wouldn't go fully into PARK and then wouldn't start unless you put it in neutral.
I don't know what to tell you about the stalling issue.
