phenolic b1 intake spacers? #477094
09/22/09 09:41 PM
09/22/09 09:41 PM
communist bloc of new jersey
jamesc Offline OP
jamesc  Offline OP
anyone used phenolic to make intake spacers for using the b1 manifold on a rb block? think it's worth the effort? i now need a set of spacers as i was smart enough to sell the ones i had
Re: phenolic b1 intake spacers? [Re: jamesc] #477095
09/23/09 05:08 AM
09/23/09 05:08 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
Same for me, if you find something or decide to make some, let me know !
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Re: phenolic b1 intake spacers? [Re: NENE] #477096
10/04/09 08:38 PM
10/04/09 08:38 PM
duluth,mn
P
psycomopar Offline
psycomopar  Offline
P
duluth,mn
did you decide to make a set. i would be interested as im going to need a pair also
Re: phenolic b1 intake spacers? [Re: psycomopar] #477097
10/05/09 11:24 AM
10/05/09 11:24 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
I'm now in the way to build a set on a CNC machine, as soon as it will be in the computer system, I will be able to make in different materials. I will let you know.....
Re: phenolic b1 intake spacers? [Re: psycomopar] #477098
10/05/09 11:56 AM
10/05/09 11:56 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i can make custom sets, whatever thickness people want. just let me know. i have open mill time right now. phenolic is not cheap material, so be prepared for some sticker shock if you've never bought any. i have been toying with the idea of a phenolic/aluminum laminated spacer which would cheaper.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: phenolic b1 intake spacers? [Re: Jerry] #477099
10/05/09 05:47 PM
10/05/09 05:47 PM
jamesc Offline OP
jamesc  Offline OP
i was just wondering if anyone had made them from phenolic and if there was any issues. i picked up a piece of 3/4 canvas phenolic off ebay for 21 bucks that should do the trick. they had another piece listed and i was going to get it in case anyone else wanted it but when i went back to check it out it was gone. i think there's two basic types that could be used for this, canvas and linen. when i get some time i'll throw it in the mill and see if i can hack this piece into shape.
thanks
Re: phenolic b1 intake spacers? [Re: jamesc] #477100
10/05/09 05:58 PM
10/05/09 05:58 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
While there are some people on here that run B1's. Will the Indy intakes work on the B1 headed RB engines? I was thinking someone said the 400(LB)intakes would work with no adapter on the RB B1 engines.Was thinking about using the Indy 400 tunnel-ram on one if it would work.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: phenolic b1 intake spacers? [Re: MRMOPAR622] #477101
10/05/09 06:15 PM
10/05/09 06:15 PM
jamesc Offline OP
jamesc  Offline OP
i'm pretty sure the intake face on the heads is different between the b1 and indys. the b1 intake face is 90° to the deck surface, i don't think the indy's are.
Re: phenolic b1 intake spacers? [Re: MRMOPAR622] #477102
10/05/09 06:18 PM
10/05/09 06:18 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I had phenoilc spacers on my B1 motor. The only issue I had was the manifold takes some time to get enough heat in it to put the engine against the 2-step.
MRMOPAR570,
The B1 and Indy heads have different angles on the mounting flanges so they will not interchange without adapters. IIRC Best Machine makes adapters for this.
Bob
