what are you guys running for a stright axle in you rod #477050
09/22/09 08:53 PM
09/22/09 08:53 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
what are you guys using for striaght axles in yuo hot rod/ rat rods.
mopar ones? thta looklike the ford style with spit wish bones?
Re: what are you guys running for a stright axle in you rod [Re: kams] #477051
09/22/09 10:55 PM
09/22/09 10:55 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Fenders or not?
Ford stuff seams to be the current "in" thing, but I'd perfer the parrelle leaf spring Mopar setup, or more likely would install an independent suspension.
That said, I recently bought a 70 Dodge pickup frame complete with the leafs and beam axle (slant 6 too ), so guess what the next one will probably be? Gene
Re: what are you guys running for a stright axle in you rod [Re: kams] #477052
09/23/09 08:25 AM
09/23/09 08:25 AM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I'm using a 32 Ford style in my 34 Dodge Highboy. I just think it looks better when you can see everything.
Arno
Re: what are you guys running for a stright axle in you rod [Re: B1arno] #477053
09/23/09 09:17 AM
09/23/09 09:17 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
I have a couple of late 40's early 50's Dodge truck straight axle setups one of which I would like to use on an early fenders roadster or roadster truck.
Re: what are you guys running for a stright axle in you rod [Re: kams] #477054
09/24/09 10:49 PM
09/24/09 10:49 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
I built a rat rod and used a A100 front axle with 72 D100 drum brakes already.
want a more traditional look to my 27 sedan Im going to build!
Re: what are you guys running for a stright axle in you rod [Re: kams] #477055
09/25/09 09:04 AM
09/25/09 09:04 AM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I used the original straight axle(which really is not straight), disc brake set up from Plydo. The disc set up uses a press on bushing for the disc which is 69 Ford Fairlane to get the Mopar bolt pattern. The brake bracket uses full size late 70's GM caliper which can be replaced with Wilwoods GMIII
caliper. The springs are mono leafs from Butch.s Rod shop(link below). Hope this helps!
http://www.butchscoolstuff.com/
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
