Help me seal my exhuast manifold for the last time. #476911
09/22/09 08:05 PM
09/22/09 08:05 PM
Fairfield Maine
hemi4speed Offline OP
Fairfield Maine
I have replaced the right side exhuast manifold Gasket 3 times..and on a hemi that is the side that you dont want to take off...I've tried Mr gasket.. stock ones, tried RTV red high temp with Gasket.. It may last a month, maybe 2. I re-torque also. The Manifolds have been resurface..any Idea's? leak is not in the same place everytime.Maybe I should no Gaskets?
Re: Help me seal my exhuast manifold for the last time. [Re: hemi4speed] #476912
09/22/09 08:22 PM
09/22/09 08:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Did you use the high temp copper rtv? My brother has mounted cast iron exhaust manifolds directly to the head with nothing more than a thin smear of copper rtv.
Might want to check and make sure that the sealing surface on the head is free of any leftover gasket residue from any previous attempts also.
Re: Help me seal my exhuast manifold for the last time. [Re: Neil] #476913
09/22/09 09:09 PM
09/22/09 09:09 PM
Fairfield Maine
Fairfield Maine
Thanks, I havent tried copper RTV..I do make sure the suface clean before mounting manifold. I may just try the copper RTV with no gasket.
Re: Help me seal my exhuast manifold for the last time. [Re: hemi4speed] #476914
09/22/09 09:25 PM
09/22/09 09:25 PM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
I've had really good luck with Permatex Copper RTV.
Re: Help me seal my exhuast manifold for the last time. [Re: Jack Zupan] #476915
09/23/09 03:29 AM
09/23/09 03:29 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
all I use is orange rtv, dont even use the copper stuff, IM cheap, I have never had an exhaust leak.
Re: Help me seal my exhuast manifold for the last time. [Re: hemi4speed] #476916
09/23/09 04:40 AM
09/23/09 04:40 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Try no gasket. I think you should check port alignment of the manifold and head before going any further. I have never had an issue with Hemi manifolds but I certainly have with 5210 Hooker headers and that was because their port alignment was terrible.
Sheldon
Re: Help me seal my exhuast manifold for the last time. [Re: RUNCHARGER] #476917
09/23/09 07:34 AM
09/23/09 07:34 AM
Indiana
Leroy Offline
Leroy  Offline
Indiana
http://www.remflex.com/
We used these on a couple different Hemi's with great luck. By far the best gasket I have ever used.
Re: Help me seal my exhuast manifold for the last time. [Re: Leroy] #476918
09/23/09 09:34 AM
09/23/09 09:34 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
REMFLEX!!!!!
Re: Help me seal my exhuast manifold for the last time. [Re: 70RR383] #476919
09/23/09 10:31 AM
09/23/09 10:31 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
I have the Remflex RF6010 in stock for alum(larger than original size port) heads! If you are running original cast iron heads and manifolds you need the RF6023 gasket.
Check the Race Parts For Sale page 1. Good prices.
Brad
Dorn Autocraft
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Help me seal my exhuast manifold for the last time. [Re: BradD] #476920
09/23/09 02:46 PM
09/23/09 02:46 PM
scratchnfotraction Offline
the red does not hold up to heat
the permatex copper is high heat and has seal all my mannys with no gaskets
I use it on headers with gaskets also
just let it cure 24 hrs first
might want to check that the exhast pipes are not to ridged
as the engine torques over it can cause them to blow a gasket or crack a manny
I use a flat file to check the surface on manny and the head at the ports to make sure the are flat
never had a hemi...but I have had lots of junk exhast systems
the copper has fixed some pitted up header flanges more than once for me
Re: Help me seal my exhuast manifold for the last time. [Re: hemi4speed] #476921
09/24/09 07:10 PM
09/24/09 07:10 PM
Pacific NW
cuda66318 Offline
cuda66318  Offline
Pacific NW
Cometic now makes a 3 Layer Stainless Steel Embossed header gasket for the 426 Hemi engines as well as the SB and R/RB blocks.
There is NOTHING Better
Google "Mopar custom Gaskets" that 4 seconds guy has 'em
Re: Help me seal my exhuast manifold for the last time. [Re: cuda66318] #476922
09/24/09 07:50 PM
09/24/09 07:50 PM
Near Indy
slowpoke Offline
slowpoke  Offline
Near Indy
I've always used Percy's deadsoft and not had a problem other than having to retorque. The Remflex gaskets look awfully sweet and aren't much more...may have to give them a look the next (dreaded)time I need to change em.
Re: Help me seal my exhuast manifold for the last time. [Re: Jack Zupan] #476923
09/24/09 08:16 PM
09/24/09 08:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Ditto for me.
Re: Help me seal my exhuast manifold for the last time. [Re: slowpoke] #476924
09/24/09 09:58 PM
09/24/09 09:58 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Re: Help me seal my exhuast manifold for the last time. [Re: sogtx] #476925
09/24/09 10:15 PM
09/24/09 10:15 PM
I have Two Late Model Dirt cars that I have used Orange RTV for years and have to pry the headers off when removing them. I don't use a gasket and just a small amount of RTV. What happens with a gasket is you give the system a weak link that can blow out. Like the thicker gaskets. If you don't retorque them all the time they flex and blow out. With just a thin layer of RTV you just fill the small imperfections in the matting surfaces and leave no place for the exhaust to blow out. All my toys have RTV and no gaskets and I have talked may people into being believers
Re: Help me seal my exhuast manifold for the last time. [Re: sogtx] #476926
09/24/09 10:16 PM
09/24/09 10:16 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
REMFLEX!!!
www.remflex.com - the last gasket you will buy for that leak!
Re: Help me seal my exhuast manifold for the last time. [Re: DJVCuda] #476927
09/26/09 10:13 AM
09/26/09 10:13 AM
Fairfield Maine
Fairfield Maine
Thanks guys..I needed a fix before Sunday, so I couldnt get the Remflex in time. So I went with ultra Copper RTV Permatex. So far no leaks. If it does leak again, I'll get a hold of BradD for some Remflex Gaskets.
