Prepping rod and main bearings?? #476589
09/22/09 01:23 PM
09/22/09 01:23 PM
owt west
Thread Ender1 Offline OP
owt west
Does anyone prep either their rod or main bearings by either scotch briting and removing the silver finish or polishing it.
It know it might be a silly question but the past 2 hi perf motors ive done i removed the coating and had no problems.
Any ideas??
Re: Prepping rod and main bearings?? [Re: Thread Ender1] #476590
09/22/09 01:27 PM
09/22/09 01:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not me.... the way they come is the way they go in
Re: Prepping rod and main bearings?? [Re: MR_P_BODY] #476591
09/22/09 02:00 PM
09/22/09 02:00 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Plastic gauge and pre lube is all my bearings see The dull gray finish is what I use for inspection after the engine has run some, if its all still there you know your close, if you show ware you still have time to look into it and check your specs
Re: Prepping rod and main bearings?? [Re: Thread Ender1] #476592
09/22/09 02:06 PM
09/22/09 02:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
Any ideas??
It use to be the standard procedure to scotch brite the new bearing in solvent and blow dry them, not today The bearing manufactures put a lot of time and money in testing the flash coatings used on todays bearings, don't waste that. I clean them with a soft cloth and laquer thinner and then coat them, once there installed into the rods or block, with the oil the motor will be ran with No magic mix of assembly lube and other potents The motor runs on oil and that is what I use
