it's 727 or not? #476376
09/22/09 05:07 AM
09/22/09 05:07 AM
Czech Republic
sejki440 Offline OP
sejki440  Offline OP
Czech Republic
it's 727 or not? pls help...
It used to my coronet 68 with the right tail housing?
68 coronet
Re: it's 727 or not? [Re: sejki440] #476377
09/22/09 07:45 AM
09/22/09 07:45 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm not sure if the output shaft on a 4X4 is the same length as a standard 727.
Re: it's 727 or not? [Re: sejki440] #476378
09/22/09 07:56 AM
09/22/09 07:56 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Yes 727. What it would take to convert for your Coronet, I don't know.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: it's 727 or not? [Re: doctor_mopar] #476379
09/22/09 08:09 AM
09/22/09 08:09 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
IIRC the out put shaft is different from 4x4 to car trans.
Output shaft and tail housng should be all you need.
Some tail housing don't have the mounting tabs for floor shift linkage.
Re: it's 727 or not? [Re: WILD BILL] #476380
09/22/09 08:59 AM
09/22/09 08:59 AM
Czech Republic
sejki440 Offline OP
sejki440  Offline OP
Czech Republic
Thank you all for your help.
68 coronet
Re: it's 727 or not? [Re: sejki440] #476381
09/22/09 09:49 AM
09/22/09 09:49 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Don't see why you would want that. I find complete 727 cores all day long for $20 to $50 on craigslist. That trans is only good for a 4X4, or for the 4 gear planetaries. What are you going to do? The output shaft is almost the first thing that goes into the trans from the front.
Re: it's 727 or not? [Re: 375inStroke] #476382
09/22/09 09:53 AM
09/22/09 09:53 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Probably not too many $20 727 cores where the poster is located.
Re: it's 727 or not? [Re: 375inStroke] #476383
09/22/09 11:15 AM
09/22/09 11:15 AM
Czech Republic
sejki440 Offline OP
sejki440  Offline OP
Czech Republic
I know, but unfortunately I live overseas, so I have to use the transmission I have. Other parts in the gearbox are small and the price of transportation is cheap ...
68 coronet
Re: it's 727 or not? [Re: sejki440] #476384
09/22/09 09:45 PM
09/22/09 09:45 PM
jonesboro, ark
ramcharger82 Offline
jonesboro, ark
i havent seen any 20 cores in my location either, memphis and little rock area. i need to move where ur at
Built not Bought
Re: it's 727 or not? [Re: ramcharger82] #476385
09/23/09 10:12 AM
09/23/09 10:12 AM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
I guess so. Here's a free 727 right now:
Free Craigslist 727
