B1 BS heads #475071
09/21/09 09:40 AM
09/21/09 09:40 AM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
Just bought a set of BS heads off e-bag they will need a little repair work but its very minor just wonderig what is the best intake to run on a low deck motor. what kind of flow numbers can you get out of these with out any welding or getting to crazy with the grinder
Re: B1 BS heads [Re: dbran451] #475072
09/21/09 01:10 PM
09/21/09 01:10 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
All I can recomend is go to the source and ask Scott.
Otherwise just a from page 3
Re: B1 BS heads [Re: dbran451] #475073
09/21/09 02:40 PM
09/21/09 02:40 PM
SoCal
Brian Hafliger Offline
SoCal
All depends on what you want. I like taking them to MW size and then they'll go 330cfm pretty easily. Give us more info on the engine and intended purpose.
OOTB they flow pretty poor by today's standards.
Brian Hafliger
Re: B1 BS heads [Re: dbran451] #475074
09/21/09 02:41 PM
09/21/09 02:41 PM
It depends on which port size they are now I had a set SR with standard 440 ports size and no porting that flowed 280 at .600 on a super Flow 600 bench, I sent them to Jeff at MCH for CNC porting to Max Wedge size and they ended up flowing 350 at .600 on the same 600 bench
Re: B1 BS heads [Re: Brian Hafliger] #475075
09/21/09 04:12 PM
09/21/09 04:12 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
the short block is a 499 low deck 12 to one compression cam motion roller cam 461/440 lobe lift 273/280 duration I'll be using 1.58 rockers.
What intake do you use when going to max wedge size
Re: B1 BS heads [Re: dbran451] #475076
09/21/09 06:48 PM
09/21/09 06:48 PM
sweden
street_dart Offline
street_dart  Offline
sweden
I run a pair on my 499 low deck. Max wedge size indy 400-3 intake. The heads flow good. I mill the heads to 67cc chamber (13.7 comp). The engine made 840Hp with a Scott Brown roller cam.
Dodge Dart-67 Dodge Custom Royal Lancer-55 Dodge Dakota 4.7 -05
Re: B1 BS heads [Re: dbran451] #475077
09/22/09 09:06 AM
09/22/09 09:06 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
...cam motion roller cam 461/440 lobe lift 273/280 duration I'll be using 1.58 rockers.
You won't get away with the BS rockers and that cam. They are not strong enough for the spring required for that cam. Your probably going to need a new set of headers too unique to that head.
Re: B1 BS heads [Re: HardcoreB] #475078
09/22/09 10:36 AM
09/22/09 10:36 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
they have relocated sparkplugs which require special headers to clear. TTI makes some. Hey Hardcore, did'nt you get some BS heads to flow around 380 CFM?(IIRC)
Re: B1 BS heads [Re: B1Fish540] #475079
09/22/09 11:07 AM
09/22/09 11:07 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Long story but, after hundreds of flow tests (self-taught) they were in the 370 range by .750". There are a few good CNC programs for them now. But flow isn't everything. (I learned to leave high HP headwork to a professional LOL.) (IMO) These heads were released in a time when there weren't many options available for BBM and their straight exit spark plug really dampens their marketablity. One addl. thing I might add is the existing pistons may need valve pocket work for radial clearence. I don't consider them an easy, practical, or economical 'bolt-on' upgrade considering what is available now.
Re: B1 BS heads [Re: HardcoreB] #475080
09/22/09 01:04 PM
09/22/09 01:04 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Wouldnt buy anything but B1's, either original or BS's.
Lots of meat in head for durability, can get great numbers with work if desired.
Didnt know it for quite a while.
Excellent people to boot.
Thought somebody had cnc program to get 350+ with a std port window.
Re: B1 BS heads [Re: theclutcher] #475081
09/23/09 04:41 PM
09/23/09 04:41 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
Thanks for the input the header issue is a new one I have not heard about before as I have a friend that has run an a body big block header on his.
I would be interested in who is cnc porting these and getting big numbers out of a non max wedge port will probably go with an Indy intake an max wedge these Dave
Re: B1 BS heads [Re: dbran451] #475082
09/23/09 05:52 PM
09/23/09 05:52 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Your friend may not have underchassis(inside the frame rails)headers(?). Not all of the plugs are unaccessable, mostly the #6 and #5...just depends how the headers are designed. Hooker can be made to work with some dinging here and there.
Re: B1 BS heads [Re: B1Fish540] #475083
09/23/09 08:07 PM
09/23/09 08:07 PM
ohio
dbran451 Offline OP
dbran451  Offline OP
ohio
they were finder well headers which is what I run also so I hope problems will be kept to a minimum
Re: B1 BS heads [Re: dbran451] #475084
09/23/09 10:45 PM
09/23/09 10:45 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
You should be fine then...
Re: B1 BS heads [Re: dbran451] #475085
09/24/09 01:18 AM
09/24/09 01:18 AM
I had Jeff at Modern cylinder head cnc port (to M.W. size) the set of B1-BS I had last year. They flowed 280 at .600 before porting with the standard 440 port size and flowed 350 at .700 after porting. I put them on a 470 C.I. 440 block with 12.0 to 1 compression, tunnel ram with two Holley 750 D.P. carbs, Crane cams custom ground solid roller that is 274@.050 and ground on a 106 LSA in at 105. that motor made 722 HP at 7000 RPM with 615 ft. lbs torque at 5400 RPM I have had other heads, and still do, that outflow the ported B1-BS but those heads did and do work very well IMHO As far as a single four barrel intake to use I would and do, use the Indy 440-2 intake (or the 400-2 for a low deck motor))with a tapered adapter for the Dominator carbs and add a one inch cloverleaf phenolic spacer under the Dominator carb.
