500+ HP from 440 How would you build it? #474111
09/20/09 10:45 PM
09/20/09 10:45 PM
Iowa
E
eaglesguy1981j Offline OP
E
Iowa
Ive been chasing my tail on this so I thought Id get yalls input. Im looking for 500+ streetable HP from a 440. Im looking for mid to low 11s with this.
Id like to use my tunnel ram and holley 600 carbs.
Id also like to stay with a Hyd cam non roller
Everything else is changeable. I know this can be done with eddy heads a big roller ect ect. But Im looking to use what I have.
I have a stock late 70s 440 block and crank. I was going to keep the bottom end stock but bump compression to around 10-10.5 with a set of forged pistions. I also have a set of 452 heads.
Tranny will be 727 prepped with about a 3000-3500 stall. A Dana 60 with 4.10 gears tires about 28-30in.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474112
09/20/09 10:54 PM
09/20/09 10:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Your first decision needs to be which heads.. And I strongly suggest something with closed chambers... Whether that's a set of 915's or one of the aluminum offerings.. It's up to you.. Eddies/Stealths/MP 452's (the new aluminum ones that are made by edelbrock for MP not the iron 452's you have) are gonna make the number alot easier.. But mostly closed chambers so quench & a reasonable compression ratio are easily attainable...
Re: 500+ HP from 440 How would you build it? [Re: 1_WILD_RT] #474113
09/20/09 11:09 PM
09/20/09 11:09 PM
Iowa
E
E
Iowa
Yeah I have actually looked at the stealths. It may be an option the price is certainly right. I figured in the stock ones to get it up and running. The stealth are 900 bucks assembled. Did I mention this is going in a A body.
Re: 500+ HP from 440 How would you build it? [Re: 1_WILD_RT] #474114
09/20/09 11:10 PM
09/20/09 11:10 PM
scratchnfotraction Offline
whats in your wallet??
it will rock in an A-body
Re: 500+ HP from 440 How would you build it? [Re: scratchnfotraction] #474115
09/20/09 11:23 PM
09/20/09 11:23 PM
Iowa
E
E
Iowa
I know its just like anything else how fast can you afford to go. I know this can be done with out big name parts and unnessary power adders. Im thinking 2500 bucks should have the majority of the hard parts done in the motor. Cam,pistons, The stealth heads. Not counting machine work.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474116
09/20/09 11:43 PM
09/20/09 11:43 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Of course it can..Probably for less than 3k total, depending on what you can do yourself. pm me
Re: 500+ HP from 440 How would you build it? [Re: Bill MeLater] #474117
09/21/09 12:31 AM
09/21/09 12:31 AM
Iowa
E
E
Iowa
I think so too. Im willing to do the work. Its not rocket science. Just make sure you measure and measure. Make sure everything is tight and right then triple check it. I know these motors make there power in the heads. So lets throw the stealths on it.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474118
09/21/09 02:00 AM
09/21/09 02:00 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Get a piston with a 2.060" or taller compression height, comp xe275hl cam, 440source stealth heads, performer rpm or holley sd intake and a set of headers and you're there. Camaro Craft did basically that build a number of years back and got some good power out of it.
http://www.carcraft.com/techarticles/116_0111_535hp_440_engine/index.html
http://www.carcraft.com/techarticles/116_0205_mopar_440_update/index.html
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474119
09/21/09 06:37 AM
09/21/09 06:37 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Are you looking for a Pump gas engine or...
This is what i built from a lowdeck, in the end, it was over 500hp i'm sure, but at 1st., it was really mild & ran 10.9s in a 3100lb. duster, i had around 3500.00 carb too pan, give or take alittle on the initial buld.
400 .030", 440 crank/rods. (counter weights cut)
Stock rods with ARP wave lock bolts
Ross FTs, 9.73, Z gap rings
906s with just a good VJ, untouched ports, stainless 208/1.74 valves.
Ductile iron rockers
Comp. XE284H, M1 single, 750 holley
1.7/8 FWs
4.11s, 28" slick, 4400 PTC 9.5"
Best: 10.91 @ 120.56 on a 1.51 in the best air.
Before i got the 4400 stall, i had a PTC 11" 3000, it pulled of an 11.12 on a 1.58 @ 120
Changes...
Added a Wieand TR & 2 600vs
Comp custom solid 529/543 (before lash), 250/256 @50 on a 108.
Home ported the 906s, flowed 264/198 with the same valves. added Caltracs
With alittle basic tuneing on the carbs, & suspention going south, the 1st. & only pass in the summer heat.
Ran a 10.87 @ 123.58 on a 1.62 60ft.
This car had 10.6s ritten all over it, just didn't 60ft. towards the end, raced it for 2 yrs. with over 250 passes on it, in all reality, it was a mild engine, but built right, they will run the #s.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474120
09/21/09 07:15 AM
09/21/09 07:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Shouldn't be hard. I'd dtich the tunel ram and use a RPM w/ a 850 DP. Your cam is going to have to fit your stall, trans and gearing. So you will need to be careful. No need for anything crazy. Good heads (iron or alum), headers and the usual bolt ons like windage tray, good hot spark, and a good tune should get you close.
Coming soon!!!!
Re: 500+ HP from 440 How would you build it? [Re: Mr.Yuck] #474121
09/21/09 07:52 AM
09/21/09 07:52 AM
Iowa
E
E
Iowa
Yes a pump gas car. Im not losing the T-ram sorry. Its staying. I know it will perform better on the street without it. Gas milage will be better without it. But I like it. I think I decided on
440 .060 over
stock rods ARP bolts
Speed Pro Dome pistons for about a 10.3 comp
Comp Cams XE285HL cam
440 source stealth heads OOTB
2x600 Holley Weiand Tunnel Ram
Dana with the 4.10s 29 inch tire
727 with a 3200 stall.
Now I just need ignition what do you guys recommend?
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474122
09/21/09 08:26 AM
09/21/09 08:26 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
What A body? I raced around with a 67 Cuda fastback
with a tunnal ram. How about a picture of the
ram. It might be to big for the street.
The 440 will work, but by the time you buy forged
pistons, have the rods resized and new rod bolts,
then turn the crank and have it polished, for a
few hundred bucks more you could do a 511 source
stroker.
Why a hyd. cam and not a solid? Solid cam will run just
as easy as hyd cam on the street, but will be of
better use with that tunnel ram.
Heads? Sell the iron 452's and get the Stealth's.
Doing up iron heads will cost almost as much as a
new set of stealth's. Dollar for dollar, the
Stealth's will out flow factory iron everytime.
I bet I already spent to much of your money.
If you do it right the first time, it won't
cost you twice the second time.
Snap your neck, mega G-force launch, is all I want!
Re: 500+ HP from 440 How would you build it? [Re: BDS871Cuda] #474123
09/21/09 08:38 AM
09/21/09 08:38 AM
Iowa
E
E
Iowa
stroker.
Lots of questions I hope I can answer them all.
1972 Plymouth Scamp. As far as the hydraulic cam. I was always told that solids are ment for the strip. That the hyd is a more streetable cam. Your exactly right on the heads. I looked at having the 452s worked. The guy wanted $899+ parts to do them. Well the stealths are $899 assembled. There also lighter. Here is a pic of the ram. Im running 2x600 VS holleys.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474124
09/21/09 08:51 AM
09/21/09 08:51 AM
Iowa
E
E
Iowa
Another picture.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474125
09/21/09 09:08 AM
09/21/09 09:08 AM
BDS871Cuda Offline
BDS871Cuda  Offline
I ran a .590-.613 solid lift cam on the street
for four years with no problem. That ram will
run better with a solid in the upper rpm range.
That ram looks to be 40 years old. used back in
the 70,s on a 440 4 speed car with a big solid
lift cam and max ported 906 heads, maybe?
Other than the Hemi, it was the next best thing for
the mopar guy.
Good luck with your build, How abouts some pictures of the car!!
Re: 500+ HP from 440 How would you build it? [Re: BDS871Cuda] #474126
09/21/09 09:14 AM
09/21/09 09:14 AM
Iowa
E
E
Iowa
Well if you really want to see it. Right now its basically just a shell. A good starting point and something I dont have to feel bad about doing a little DNC to.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474127
09/21/09 09:15 AM
09/21/09 09:15 AM
Iowa
E
E
Iowa
One more for ya. Im basically collecting parts at the moment. Only had it home for about 4 months. My first project car ever. Got her home for 300 bucks. Pretty complete too except the interior and the engine compartment. Some parts ive take off for repairs and to keep safe.
Re: 500+ HP from 440 How would you build it? [Re: BDS871Cuda] #474128
09/21/09 09:17 AM
09/21/09 09:17 AM
Iowa
E
E
Iowa
the mopar guy.
Well Ill tell you what. You seem pretty knowledgeable about these. Could you suggest a cam that would work well with this. Yes the ram is old. But I like the nostalgia(spelling) look it gives off.
Re: 500+ HP from 440 How would you build it? [Re: eaglesguy1981j] #474129
09/21/09 10:27 AM
09/21/09 10:27 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Just out of curiousity what brand and model is that tunnelram?
Re: 500+ HP from 440 How would you build it? [Re: Blakcharger440] #474130
09/21/09 10:52 AM
09/21/09 10:52 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The hyd flat tappet cam works great and offers the simplicity, reliability and low cost of stamped steel rocker arms. The solid will make more power but will require the added cost of adj rocker arms with additional high quality adjusters, the correct push rods and the occasional lash adustments. I suggest for a super hot street driver to stick with the hyd flat tappet cam with good stamped arms.
Keep old mopars alive.
