Recommendations for rim sizes on a 73 Charger #473754
09/20/09 06:47 PM
09/20/09 06:47 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Guys,
I am finally getting my car restored and it will soon be time to pick out the rims/tires to go on my Charger. I DO NOT want to use the stock spoke hubcaps!
It is a 1973 Charger with an 8 3/4" rear. Can you recommend a good rim size with wider-than-stock tires but no scrub? Im thinking 15" or 16" max as far a diameter.
Also I am not very knowledgeable about this but does anyone know what backspacing, offset, etc I will need? The car/axel is stock except for a SSBC disk conversion which fits fine under the stock rims...
Any thought's on which specific rim you guys like? Any input is appreciated!
Re: Recommendations for rim sizes on a 73 Charger [Re: cjskotni] #473755
09/20/09 08:16 PM
09/20/09 08:16 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Re: Recommendations for rim sizes on a 73 Charger [Re: cjskotni] #473756
09/20/09 08:24 PM
09/20/09 08:24 PM
Kent, WA
triple_green Offline
Kent, WA
The standard "enhanced stock" mopar muscle car look with the 15" magnums is front 15"x7", with 4.25" backspacing 235 60 15 tires
rear 15"x8", with 4.5" backspacing, 275 60 15 tires.
this gives you a 2" taller than stock tire in the rear, but a "beefy" looking tire.
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Recommendations for rim sizes on a 73 Charger [Re: triple_green] #473757
09/20/09 08:51 PM
09/20/09 08:51 PM
Central NC
gch Offline
gch  Offline
Central NC
I ran 15x8 with 275/60/15 on the rear and 15x7 with 245/60/15 on the front.255/60/15's will fit on the front if your ride height is'nt too low.A more common front sixe is 225/70/15 if you don't want wide tires on the front.
8" with 4.5 backspace will clear on the rear.Front backspacing is'nt a concern.
Re: Recommendations for rim sizes on a 73 Charger [Re: cjskotni] #473758
09/20/09 09:10 PM
09/20/09 09:10 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Quote: "Guys, I am finally getting my car restored and it will soon be time to pick out the rims/tires to go on my Charger."
If you're truely going to "Restore" your Charger (you did say Restore, right?) I would consider 15x7 Rallyes with maybe a 245/60/15 on all four corners.
I think the Firestone "Indy" series tires in 245/60/15 look very close to the G60 Belted tires of the day.
That's the biggest wheel combo I can think might have come on your '73 from the factory.
Now if you're intention is to "Restiy" or perform a "Restification" on your car, that's a whole different story, and perhaps even a better description of your true intentions as you mentioned the possibility of entertaining a 16" wheel on your charger.
Have you considered aftermarket 15" or even 16" chromed rallyes or magnum 500's?
4.5" back spacing is the way to go.
Good luck and please post some pics of your car once the Restoration is completed.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Recommendations for rim sizes on a 73 Charger [Re: Hoof Hearted] #473759
09/20/09 10:36 PM
09/20/09 10:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have 15x7's with a 4.25" backspacing on all 4 corners. Front tires are 235/60/15, rears are 275/60/15. I am very happy with the front tires, but next time I'm going with a wider rear tire and a wider rim. The 275's don't look big at all on my car.
So what if you're saying if he does't put factory rims/tires on it, it's not a restored car? Hmm, I wonder where all those hours and $$ went then...
Re: Recommendations for rim sizes on a 73 Charger [Re: DaytonaTurbo] #473760
09/20/09 10:49 PM
09/20/09 10:49 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Thanks guys! I am looking at these for the rear and the 15x7 for the front...
http://www.summitracing.com/parts/WVI-54-5812042/
I appreciate the help so far.
My project is a resto-mod. My drivetrain is numbers-matching but I am adding the bulge hood and have bored/stroked my motor and added aluminum goodies . The rims being "correct" is really not a concern for me as long as they look "right" i.e. not huge chrome rims.
Re: Recommendations for rim sizes on a 73 Charger [Re: cjskotni] #473761
09/20/09 11:44 PM
09/20/09 11:44 PM
S.E. Conn
S.E. Conn
Oh, it's gonna be a Resto-Mod.
Now I understand your question.
The word "Restore" really confused me almost as much as the words "frame off" and "Mopar, Dodge or Plymouth" do when used in the same sentence.
My bad. Peace out. (some more words used improperly)
2005 300C Hemi
Re: Recommendations for rim sizes on a 73 Charger [Re: Hoof Hearted] #473762
09/25/09 03:32 PM
09/25/09 03:32 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Ok guys, I appreciate your input so far. Here is what I have decided to get for the Charger:
Rear:
Wheel Vintiques 54 series Magnum 500
15x8" rim size with a 4.5" backspacing, no offset
Cooper Cobra GT, P275/60R15
Front:
15x7" rim size with a 4.25" backspace, +6mm offset
Cooper Cobra GT, P235/60R15
These all have a 5x4.5" bolt circle which I believe is correct for the 8 3/4" axle. Can you guys check this over and make sure this looks right? I would measure some of these things myself but I don't have easy access to the car right at the moment.
Once I get the warm and fuzzy from some people here that are more knowledgeable, I might go ahead and order these babies!
Thanks in advance!
Re: Recommendations for rim sizes on a 73 Charger [Re: cjskotni] #473763
09/25/09 03:47 PM
09/25/09 03:47 PM
Manitoba, Canada
Manitoba, Canada
Looks fine to me.
Re: Recommendations for rim sizes on a 73 Charger [Re: DaytonaTurbo] #473764
09/25/09 03:51 PM
09/25/09 03:51 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Does anyone know what size the threads are on the wheel studs? I seem to remember 7/16x20...but I want to be sure.
Thanks!
Re: Recommendations for rim sizes on a 73 Charger [Re: cjskotni] #473765
09/25/09 04:01 PM
09/25/09 04:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
same as any mopar... 1/2" 20
Re: Recommendations for rim sizes on a 73 Charger [Re: NachoRT74] #473766
09/25/09 04:52 PM
09/25/09 04:52 PM
Central NC
gch Offline
gch  Offline
Central NC
Bear in mind the 235 is 2" shorter than the 275.It will have a good rake to the stance.If that is too much consider a 245 on the front.Also consider header/oil pan clearance with the front end low with the 235's.
