BB Aluminum Water Pump Housings #473197
09/20/09 10:21 AM
09/20/09 10:21 AM
Bethlehem, PA
Beemeister Offline OP
Bethlehem, PA
Has anyone ever done a comparison of the different Big Block Al water pump housings? There is the MP one, one from 440 Source, plus EBAY has a few, and who knows where else. Which one do you have and how do you like it? Any to avoid for performance issues?
'70 Coronet 500. Now 440/727. AC/ps/pb
Re: BB Aluminum Water Pump Housings [Re: Beemeister] #473198
09/20/09 10:23 AM
09/20/09 10:23 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i have 5 or 6 early/mid 70,s mopar direct connection ones that look exactly like the originals thats all i would ever use! dan
Re: BB Aluminum Water Pump Housings [Re: Beemeister] #473199
09/20/09 10:25 AM
09/20/09 10:25 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: BB Aluminum Water Pump Housings [Re: JohnRR] #473200
09/20/09 03:35 PM
09/20/09 03:35 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
I have seen lots of cheap "CAT' brand housing on ebay lately, haven't heard anything about there quality though
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: BB Aluminum Water Pump Housings [Re: megajoltman] #473201
09/20/09 03:46 PM
09/20/09 03:46 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have an Aluminum passenger side inlet model from 440 source, No problems with it.
Re: BB Aluminum Water Pump Housings [Re: Azzkikrcuda] #473202
09/20/09 09:16 PM
09/20/09 09:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought my aluminum housing and pump from Mancini as it was their brand. The told me the only difference from the MP one was the Mopar name on it. And the MP one is $110. dollars more. But the Mancini one works fine for me. Ron
Re: BB Aluminum Water Pump Housings [Re: 383man] #473203
09/20/09 09:49 PM
09/20/09 09:49 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Go read some of the comments on the Dodge Charger forum, under: Mopar Garage; Engine, Transmission, Rearend, & Exhaust, 2nd thread about overheating issue resolved.
Ron
http://www.dodgecharger.com/forum/index.php/board
Re: BB Aluminum Water Pump Housings [Re: Ronnman] #473204
09/20/09 10:24 PM
09/20/09 10:24 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Back when the National Hemi Owner was still running in the late 70s early 80 the News Letter hade a fantastic article comparing all the Hemi/BB Water pump housings and all the different pumps. One thing I remember was when we all got together and talked about the article at one of the meets was a lot of people stated that these units Housing and Pumps must be a matted unit or it will cavitage behind the pump in the house causing over heating.
1971 HEMI E BODY REGISTRY
Re: BB Aluminum Water Pump Housings [Re: Ronnman] #473205
09/21/09 01:19 AM
09/21/09 01:19 AM
Bethlehem, PA
Bethlehem, PA
Ronnman,
Thanks for the link. It was a lot of reading, but well worth it. I now know where I will get the housing/pump when the time comes. Until then, I'll stay with my stocker.
Re: BB Aluminum Water Pump Housings [Re: Azzkikrcuda] #473206
09/21/09 10:35 AM
09/21/09 10:35 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I have the same one from Source also and it works just fine with no modifications.
Re: BB Aluminum Water Pump Housings [Re: Ronnman] #473207
09/21/09 12:10 PM
09/21/09 12:10 PM
JohnRR Offline
JohnRR  Offline
Ron
interesting link
Re: BB Aluminum Water Pump Housings [Re: JohnRR] #473208
09/21/09 06:58 PM
09/21/09 06:58 PM
Wichita,KS
Wichita,KS
I would like to add that currently I am not using the 440Source waterpump but only the housing.
I am using a stock like over the counter water pump with the 440source housing. I did have a 440 souce water pump on my engine but discovered that it was too thick and made the bolts rub against my billet water pump pulley so I did not use it....apparently I may have dodged a potential overheating problem with the 440 source water pumps.
Re: BB Aluminum Water Pump Housings [Re: Blakcharger440] #473209
09/21/09 09:54 PM
09/21/09 09:54 PM
Portland Oregon
JohnnyBeGood Offline
Portland Oregon
So lets make this as painless as possible what is the best housing to use and water pump-aluminum of coarse!
Re: BB Aluminum Water Pump Housings [Re: JohnnyBeGood] #473210
09/22/09 09:22 AM
09/22/09 09:22 AM
JohnRR Offline
JohnRR  Offline
Mopar or Mancini housing , Milodon pump .
Re: BB Aluminum Water Pump Housings [Re: Beemeister] #473211
09/22/09 08:42 PM
09/22/09 08:42 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I had the same problem with the 440 Source water pump houseing and water pump To much heat at the top of motor. it got so hot could not put my hand on th carbs. I put my stock cast back on and Bingo
problem solved !!!
I would still like to go with the aluminun set up , I will be calling Mancine and see what
they have to say about their units
I will not deal with 440 Sourse again
Re: BB Aluminum Water Pump Housings [Re: TOMRR] #473212
09/22/09 09:58 PM
09/22/09 09:58 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Is it their housing or just a cheap water pump thats the problem from 440 source?
Re: BB Aluminum Water Pump Housings [Re: JohnRR] #473213
09/22/09 10:13 PM
09/22/09 10:13 PM
SE Pa.
LimeliteAero Offline
SE Pa.
John,
Thats the first time Ive heard someone recomend the Milodon pump. Have you had good results or is this just considered the new ticket?
Re: BB Aluminum Water Pump Housings [Re: LimeliteAero] #473214
09/22/09 11:35 PM
09/22/09 11:35 PM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Maybe i'm old fashioned but, I have a hard time seeing the need for aluminum water pump and housing for a street machine. Rather put those dollars elsewhere. I had alumimum units on my race car just for weight savings..actually only saved about 8 pounds i think.
Maynard
Re: BB Aluminum Water Pump Housings [Re: LimeliteAero] #473215
09/23/09 08:45 AM
09/23/09 08:45 AM
JohnRR Offline
JohnRR  Offline
John,
Read the thread that is linked above, I have the milodon pump , haven't run it yet though.
Re: BB Aluminum Water Pump Housings [Re: DartGTS] #473216
09/23/09 08:47 AM
09/23/09 08:47 AM
JohnRR Offline
JohnRR  Offline
Hello:
Maynard
That's why people are using them , the weight savings , I have ground on the one I have to make it LOOK stock , the nose of my BB A body is heavy enough.
