Yoke bushing install Question on AAR cuda. #473040
09/20/09 04:46 AM
09/20/09 04:46 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
I am ready to install a new yoke busing on my manuell A 833 extension housing.
Anyone who know which way should the hole in the bushing turn?
Lau.
Re: Yoke bushing install Question on AAR cuda. [Re: AAR70] #473041
09/20/09 06:31 AM
09/20/09 06:31 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
There is a groove machined in the tailhousing. Line up the slot in the bushing with the groove and drive it home. The small hole in the seal boot faces down.
MB
Re: Yoke bushing install Question on AAR cuda. [Re: AAR70] #473042
09/20/09 09:54 AM
09/20/09 09:54 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Lau.
Nice tool!!
I was just looking at my yoke on my 727 and thought it was loose. probably need to get that replaced soon
Re: Yoke bushing install Question on AAR cuda. [Re: aarcuda] #473043
09/20/09 09:56 AM
09/20/09 09:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Lau.
Nice tool!!
Steve , I have the tools in that picture , shoot me your address if you think you are goingto do it and I'll send them down .
Re: Yoke bushing install Question on AAR cuda. [Re: JohnRR] #473044
09/20/09 10:56 AM
09/20/09 10:56 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
This shows the relationship between the slot in the bearing and the groove in the housing.
Re: Yoke bushing install Question on AAR cuda. [Re: Snoopy] #473045
09/20/09 03:13 PM
09/20/09 03:13 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej,do anyone know if that tool is still availible for buying somewhere?i lay under my cuda 4 speed and i could jank the prop shaft up and down a lot,at least 1/ 16" if not more.if i where in us of a i would send it to passon or brewers but im in sweden,hej aar.is there somewhere to buy special tools for a 4speed? over and out.
Re: Yoke bushing install Question on AAR cuda. [Re: cuda-sweden] #473046
09/20/09 05:05 PM
09/20/09 05:05 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Just get the tool and do it yourself. A five year old can do it with that tool. I would venture to guess that even a good trans shop in Sweden or Kazakhstan might have the tool, it's been around for 40 years. The bushing is the same as a 727, and it's also the same as a Ford C-6.
MB
Re: Yoke bushing install Question on AAR cuda. [Re: cuda-sweden] #473047
09/20/09 07:17 PM
09/20/09 07:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes , Miller /SpX has the tools in the picture above , if you do a search of posts by the thread starter you will find the thread where he asks about the tools and I gave him the link for the tools .
Re: Yoke bushing install Question on AAR cuda. [Re: JohnRR] #473048
09/20/09 07:24 PM
09/20/09 07:24 PM
Snoopy Offline
Snoopy  Offline
John, you could have put the links here in less time than it took you to send him searching.
Information provided by Johnahah.
Puller: http://millerspecialtools.spx.com/Detail.aspx?id=255
Installer: http://millerspecialtools.spx.com/Detail.aspx?id=250
Re: Yoke bushing install Question on AAR cuda. [Re: JohnRR] #473049
09/20/09 10:32 PM
09/20/09 10:32 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Lau.
Nice tool!!
I'll let you know!. i'll probably need to yank the tranny out to replace the rear drum and band this winter so I'll keep your offer in mind- if I cant borrow one from an acquaintance that owns a tranny shop
Re: Yoke bushing install Question on AAR cuda. [Re: Snoopy] #473050
09/21/09 04:28 AM
09/21/09 04:28 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
thanks guys for the link,im going to buy one of those.great.and of course im going to do it myself.i have more issues with it but its working ok so far.i guess i can rebuild it myself when its time,with the help from you guys it will be fine.thanks
Re: Yoke bushing install Question on AAR cuda. [Re: cuda-sweden] #473051
09/22/09 11:07 AM
09/22/09 11:07 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Thank you guy´s for answer
Anders ,you can borrow the Miller/spx tool from me!
Lau
