slick size early b body? #471802
09/18/09 02:49 PM
09/18/09 02:49 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
How tall and wide a slick can you get in an early b body (63 dodge) stock wheel house?
Re: slick size early b body? [Re: mprhound] #471803
09/18/09 03:17 PM
09/18/09 03:17 PM
London,Ontario,Canada
1962Savoy Offline
1962Savoy  Offline
I put a 30x 10.5 inch Pie Crust Radir under my stock 62 savoy. there isnt much more room that that!
Re: slick size early b body? [Re: 1962Savoy] #471804
09/19/09 07:21 AM
09/19/09 07:21 AM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
28X10.5 M/T on a 64 Belvedere with no problem. Ran a M/T 29565R15 drag radial, 30 in. tall, and they hit the front of the wheel opening when they grew. (yes, they grow)
Re: slick size early b body? [Re: maxi426] #471805
09/19/09 11:18 AM
09/19/09 11:18 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
what about a 29.5 x 10.5, would that hit the front of the wheel well? anybody run them before?
Re: slick size early b body? [Re: mprhound] #471806
09/19/09 12:20 PM
09/19/09 12:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are 30 x 9 Hoosier radial slicks on my 63 Sport Fury and they fit perfect. No rubbing at all. I had 29 x 11.5 Hoosier QTP tires on it and they fit with about 1/4 to 1/2" clearence on the spring and fender sides. But they would rub alot on turns. So much that smoke was coming out of my wheelwell turning on a highway ramp. So I drive it on the 30 x 9 Hoosier radial slicks because nobody makes a 30 x 9 drag radial. But the 30" tall fits with room to spare hieght wise. Ron
Re: slick size early b body? [Re: 383man] #471807
09/19/09 12:23 PM
09/19/09 12:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These tires in my sig pic were the 29 x 11.5 Hoosier QTP tires. They just rub to much on turns. Ron
Re: slick size early b body? [Re: 383man] #471808
09/19/09 04:57 PM
09/19/09 04:57 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
We've always run either 29.5x9.0 or 30x9.0 slicks on our '64 Savoy using a 15x8 wheel w/ 4.5" backspacing.
These are 30x9.0 Firestones in this pic.
Re: slick size early b body? [Re: Blues_Cuda] #471809
09/19/09 05:11 PM
09/19/09 05:11 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Scott, do the Cal Tracs prevent you from running a wider tire?
Re: slick size early b body? [Re: 64Post] #471810
09/19/09 09:25 PM
09/19/09 09:25 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
No.
The slicks come close to the wheel lip on the drivers side. I think we had to do some slight trimming actually. The Firestone slicks rubbed the leaf spring a little bit too. Not bad by any means though. Those Firestones balloon out a lot for only being a 9" wide tire. We will be running 30x9.0 M/T ET Drags the next time we take it to the track.
It's a '68 B-Body Dana in the stock spring location.
How have you been doing Dave?
Re: slick size early b body? [Re: Blues_Cuda] #471811
09/21/09 10:19 AM
09/21/09 10:19 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
The slicks come close to the wheel lip on the drivers side. I think we had to do some slight trimming actually. The Firestone slicks rubbed the leaf spring a little bit too. Not bad by any means though. It's a '68 B-Body Dana in the stock spring location.
I am running a 67 b body width rearend, should give me a hair more room on the wheel lip side, you did not have any problems with the 30 inch tire getting into the wheel well in the front?
Re: slick size early b body? [Re: Blues_Cuda] #471812
09/21/09 10:22 AM
09/21/09 10:22 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
What rear springs are you running mono-leaf or stock style?
Re: slick size early b body? [Re: mprhound] #471813
09/22/09 10:47 PM
09/22/09 10:47 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
It's close on ours, but it has never hit the front.
Re: slick size early b body? [Re: mprhound] #471814
09/22/09 10:48 PM
09/22/09 10:48 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Stock-style springs made by St. Louis Spring. We'll get some mono-leafs on there one day.
Re: slick size early b body? [Re: Blues_Cuda] #471815
09/23/09 09:53 AM
09/23/09 09:53 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
thanks to all for the info, now I can look at slicks.
