Re: slick size early b body?
[Re: 383man]
#471807
09/19/09 12:23 PM
09/19/09 12:23 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
These tires in my sig pic were the 29 x 11.5 Hoosier QTP tires. They just rub to much on turns. Ron
[Re: Blues_Cuda]
#471809
09/19/09 05:11 PM
09/19/09 05:11 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
We've always run either 29.5x9.0 or 30x9.0 slicks on our '64 Savoy using a 15x8 wheel w/ 4.5" backspacing.
These are 30x9.0 Firestones in this pic.
Scott, do the Cal Tracs prevent you from running a wider tire?
[Re: 64Post]
#471810
09/19/09 09:25 PM
09/19/09 09:25 PM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
No.
The slicks come close to the wheel lip on the drivers side. I think we had to do some slight trimming actually. The Firestone slicks rubbed the leaf spring a little bit too. Not bad by any means though. Those Firestones balloon out a lot for only being a 9" wide tire. We will be running 30x9.0 M/T ET Drags the next time we take it to the track.
It's a '68 B-Body Dana in the stock spring location.
How have you been doing Dave?
[Re: Blues_Cuda]
#471812
09/21/09 10:22 AM
09/21/09 10:22 AM
Posts: 409 Texas
mprhound
Texas
What rear springs are you running mono-leaf or stock style?
[Re: mprhound]
#471813
09/22/09 10:47 PM
09/22/09 10:47 PM
Blues_Cuda
St. Louis, MO
I am running a 67 b body width rearend, should give me a hair more room on the wheel lip side, you did not have any problems with the 30 inch tire getting into the wheel well in the front?
It's close on ours, but it has never hit the front.
[Re: mprhound]
#471814
09/22/09 10:48 PM
09/22/09 10:48 PM
Blues_Cuda
St. Louis, MO
Stock-style springs made by St. Louis Spring. We'll get some mono-leafs on there one day.
