Powering a winch
#470516
09/16/09 09:55 PM
09/16/09 09:55 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I have a Superwinch4500, I never remember to charge the trailer battery, it's an open trailer, battery is not mounted to trailer. I usually end up plugging my battery charger into my generator and running the winch off the battery charger. Tonite I noticed my generator has red and black studs marker "12 volt 10 amp". Can I just run my 2 winch wires right to that and run it straight off the generator? Is 10 amps enough?
Re: Powering a winch
[Re: Sport440]
#470522
09/16/09 10:22 PM
09/16/09 10:22 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
My first winch was powered by the vans battery. I just ran heavy gauge wire back to a quick disconnect.
[Re: WILD BILL]
#470524
09/16/09 10:48 PM
09/16/09 10:48 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Something like THIS
If you dont want to mess with a second battery, Wild Bills way, is well the Way to go.
For the price Id recommend it, it sure beats messing with a second Batt on a open trailor. mike
[Re: WILD BILL]
#470525
09/17/09 12:06 AM
09/17/09 12:06 AM
Posts: 256 Lenox, MI
gj69charger
Lenox, MI
I have that set up and it works fine.
[Re: Sport440]
#470526
09/17/09 05:59 AM
09/17/09 05:59 AM
ProSport
Akron, Ohio
I like that Wild Bill! Reminds me of years ago when I used 2 sets of jumper cables hooked together to run my winch off the truck battery. This would eliminate the trailer battery. Bill, did you run these wires through the vehicle and leave them on all year round? Or do you just clamp them to your truck/van battery when you use the winch? Solar panel would be cool too.
[Re: WILD BILL]
#470530
09/17/09 10:46 AM
09/17/09 10:46 AM
Posts: 767 NW PA
V10nacuda
NW PA
I have a similar setup on both trucks....Just used good wire & ran it from the battery of the truck back to the rear bumper & terminated it with a lift truck type electrical connector.. about $8.00 a piece. Have a lead from the winch with the same deal so it can be disconnected & then to keep the road grime out of the connector when the truck is being driven just sealed another connector with silicone & some dielectric grease. Dont forget the breaker between the battery & the long run to the back of the truck. One thing I do have is the winch mounted on a reciever type hitch so it can connect to the trucks or the trailer... Really came in handy this winter when I got hung up in the snow. Grabbed onto a big tree with the winch & poof... Self recovery.
Come check it out at Norwalk... I owe you a from last year when I ran out.
V10
[Re: Crizila]
#470532
09/17/09 12:21 PM
09/17/09 12:21 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Another idea, with an open trailer, would be to simply drive the car on and off the trailer, thus no need for a winch I do it all the time, works great
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: ProSport]
#470533
09/17/09 01:03 PM
09/17/09 01:03 PM
Posts: 993 Mid Michigan
Mr. Smurf
Mid Michigan
I made a long set of "jumper" cables. Got some bulk battery cable and heavy duty clamps from the local truck parts place, then put welder quick disconnects on the other end & on the winch. Kind of a pita, but it allows me to use the trailer/winch with different trucks. The trailer winch is a Ramsey re8000.
Ed
[Re: nss guy]
#470534
09/17/09 03:07 PM
09/17/09 03:07 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
I drive the car in and exit thru the roll down driver's window[ Jack be nimble?] Carry a jump pak and use a $69 12v winch when tragedy hits. Slower, but pulls this 3200lb OK.
The little old lady from Pasadena is back!
