70 b body with woodgrain weel #46987
10/30/07 01:09 PM
10/30/07 01:09 PM
yellow70charger Offline OP
question #1 where can i get one restored?
question #2 is the steering column filler piece supposed to be silver or black?
question #3 Does anyone reproduce the horn pad?
Re: 70 b body with woodgrain weel [Re: yellow70charger] #46988
10/30/07 06:02 PM
10/30/07 06:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
1) Doug Lepak http://members.shaw.ca/stwheels/index.htm
2) Silver
3) No not that I'm aware of but nice originals aren't that hard to find..
Re: 70 b body with woodgrain weel [Re: 1_WILD_RT] #46989
10/30/07 06:08 PM
10/30/07 06:08 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
3) Yes I have seen it at Carlisle this year.....can't remember the vendor off the top of my head....
1MYTGTX
Re: 70 b body with woodgrain weel [Re: yellow70charger] #46990
10/30/07 08:47 PM
10/30/07 08:47 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
See my signature.
Black for 70.
www.automedicsupply.com
Re: 70 b body with woodgrain weel [Re: 1_WILD_RT] #46991
10/30/07 09:07 PM
10/30/07 09:07 PM
Edmonton , Alberta , Canada
stwheels Offline
stwheels  Offline
Thanks Randy
yellow70charger, drop me a line so I can send you the questions I need answered to give you a price.
I'm also able to re-plate your spokes if they are rusty, pitted or peeling. This is a picture of a refinished wheel with re-plated spokes in the original satin sheen.
e-mail: stwheels@shaw.ca
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #46992
10/30/07 09:12 PM
10/30/07 09:12 PM
stwheels Offline
stwheels  Offline
A shot of my wood grain. All drawn by hand.
Re: 70 b body with woodgrain weel [Re: yellow70charger] #46993
11/01/07 11:37 AM
11/01/07 11:37 AM
plumbeeper Offline
plumbeeper  Offline
Re: 70 b body with woodgrain weel [Re: plumbeeper] #46994
11/01/07 12:00 PM
11/01/07 12:00 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Like most of the rest of my car, I'm likely to tackle the wheel resto for my '70 Bee myself but the outer wheel 'rim' is missing. Is there a source for this part?
Re: 70 b body with woodgrain weel [Re: Quikshft] #46995
11/01/07 12:07 PM
11/01/07 12:07 PM
stwheels Offline
stwheels  Offline
Jeff, if you mean the steel ring, you'll likely have to find one from a donor wheel ... but then you might as well just re-finish the complete wheel.
I'm sure there is some source out there in the manufacturing world but none that I've come across yet.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #46996
11/01/07 12:28 PM
11/01/07 12:28 PM
stwheels Offline
stwheels  Offline
Here are a series of photos showing a wheel I recently completed. It also was missing it's outer steel ring but I had a spare one lying around.
This is a crack in the rim and the groove where the ring should be.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #46997
11/01/07 12:31 PM
11/01/07 12:31 PM
stwheels Offline
stwheels  Offline
This shot shows how the rim has shrunk and the inner ring no longer fits either.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #46998
11/01/07 12:33 PM
11/01/07 12:33 PM
stwheels Offline
stwheels  Offline
This shot shows a test fitting of the outer ring before the repair work is started.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #46999
11/01/07 12:38 PM
11/01/07 12:38 PM
stwheels Offline
stwheels  Offline
Next the original groove is filled with resin and then a layer of random weave carbon fiber cloth is applied around the outside of the rim and across any cracks.
2 coats of resin are spread over the carbon fiber building a shell around the wheel. The gaps around and behind the inner ring are also filled so it is no longer loose.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #47000
11/01/07 12:39 PM
11/01/07 12:39 PM
stwheels Offline
stwheels  Offline
After sanding the resin smooth the outer ring is test fit again.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #47001
11/01/07 12:42 PM
11/01/07 12:42 PM
stwheels Offline
stwheels  Offline
With the outer ring in place I apply resin to build up the rim around it. This ensures the inner and outer rings will have no gaps around or behind them.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #47002
11/01/07 12:45 PM
11/01/07 12:45 PM
stwheels Offline
stwheels  Offline
On to the sanding. The resin is filed and sanded down so it leaves the rings flush with the surface of the rim. Nothing will be coming loose on this wheel again.
The inner ring.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #47003
11/01/07 12:46 PM
11/01/07 12:46 PM
stwheels Offline
stwheels  Offline
The outer ring.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #47004
11/01/07 12:49 PM
11/01/07 12:49 PM
stwheels Offline
stwheels  Offline
Now the rings are masked off and the Brown wood color is airbrushed onto the rim. Once set, I recreate all the wood grain by hand.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #47005
11/01/07 12:51 PM
11/01/07 12:51 PM
stwheels Offline
stwheels  Offline
More painting ! Several coats of clear acrylic urethane (Glasurit/BASF brand paints) are sprayed on the rim. This seals the wood graining and the steel rings under a smooth incredibly durable surface.
Doug Lepak
Re: 70 b body with woodgrain weel [Re: stwheels] #47006
11/01/07 12:54 PM
11/01/07 12:54 PM
stwheels Offline
stwheels  Offline
After the clear sets for a few days I buff down the finish to a satin sheen that duplicates the factory look.
Voila ! Plus I can re-plate the spokes to the proper satin sheen. The wheel pictured has had the spokes re-plated.
Doug Lepak
