My electric fuel pump is haunted! #469757
09/16/09 07:25 AM
09/16/09 07:25 AM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
Just got a knock on the door from my neighbor. Apparently my electric fuel pump was running and the truck was turned off. Haven't driven it in a couple days and it's completly dry weather out so I don't think it was a short. I turned on the ignighton, then turned it off and the pump then turned off with it. Also, the pump sounded louder that usual. Never had a problem with it before and looks to be pretty new. Any idea what might be going on with it?
It's Purotator A12 pump if that makes a diffrence.
Re: My electric fuel pump is haunted! [Re: migsBIG] #469758
09/16/09 08:14 AM
09/16/09 08:14 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Is it powered by a relay?
Re: My electric fuel pump is haunted! [Re: Challenger 1] #469759
09/16/09 11:22 AM
09/16/09 11:22 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
I don't see one, though it was installed on the truck when I got it.
Re: My electric fuel pump is haunted! [Re: migsBIG] #469760
09/16/09 11:31 AM
09/16/09 11:31 AM
Cincinnati, Ohio
Cincinnati, Ohio
Fuel pumps use alot of juice typically. I bet your electric contacts/switch are burnt. Could be very dangerous, you should install a relay to handle the load.
Re: My electric fuel pump is haunted! [Re: Challenger 1] #469761
09/16/09 03:10 PM
09/16/09 03:10 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree 100%, install a relay, & for now, i would disconnect the wiring so it doesn't cause a major problem for you.
Oh, & get a damn good switch, no cheapo stuff, the cheapo's will short out between the contacts when heavy loads are put on them, even though it says it'll handle 30amps, yeah right!!
Also run at least a 10 gage wire.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: My electric fuel pump is haunted! [Re: joedust451] #469762
09/16/09 06:41 PM
09/16/09 06:41 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Thanks for input. I've never installed one before, do you guys have idea of which one to buy or where to order it??
Re: My electric fuel pump is haunted! [Re: migsBIG] #469763
09/16/09 07:35 PM
09/16/09 07:35 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
They have them at O'Reilly's or AutoZone, you can use the 4 prong 30 Amp. & a good 30 amp switch, just get the one with the connection plug that has the wires, i'm sure someone can post a pic on how to wire up an elec. pump through a reg. & switch. If i remember, there will have a Red/Orange/Green/Black wires.
Re: My electric fuel pump is haunted! [Re: joedust451] #469764
09/17/09 05:14 AM
09/17/09 05:14 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Thanks for the info. Electrics is my weak point, so this of great interest to me.
Re: My electric fuel pump is haunted! [Re: migsBIG] #469765
09/17/09 04:07 PM
09/17/09 04:07 PM
IL
furious70 Offline
furious70  Offline
IL
search for them on amazon, you can get them for a couple bucks and the pig tails for the same. That's where I got mine for my efi conversion.
like this:
http://www.amazon.com/Tyco-Relay-SPDT-Fo...8358&sr=8-5
links to the pigtails in there too
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: My electric fuel pump is haunted! [Re: furious70] #469766
09/25/09 09:37 AM
09/25/09 09:37 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
thanks for the link.
