what size oil restrictor? #469543
09/15/09 09:29 PM
09/15/09 09:29 PM
Plymouth Meeting, PA
bigtimeauto Offline OP
Trophy Winner
Trophy Winner
Just got done priming my engine with my new T&D rockers. Boy do these things bleed off some oil. What size restrictors are you guys running with 440-1 heads?
thanks
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: what size oil restrictor? [Re: bigtimeauto] #469544
09/15/09 09:36 PM
09/15/09 09:36 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
ha ha ha ...tell me about it ...they FLOOD the oil out onto the valves. I am using .060 nitrous jets as oil restrictors
....BAD A$$ STREET CAR.....
Re: what size oil restrictor? [Re: n20mstr] #469545
09/15/09 09:51 PM
09/15/09 09:51 PM
Trophy Winner
Trophy Winner
I'm off to the dyno in the morning and don't want to pump it dry!
thanks Tony!
Re: what size oil restrictor? [Re: n20mstr] #469546
09/15/09 09:53 PM
09/15/09 09:53 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
how much are t&d's for 440*-1's ....
Mopar Performance
Re: what size oil restrictor? [Re: moparniac] #469547
09/15/09 11:22 PM
09/15/09 11:22 PM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
i used the 64's that were in my Holley jet box..i wanted to use 55-60 but figured as long as i slowed down that massive oil flow and kept it in the pan the better off i was.. instead of tapping just the t-block in the block i tapped both fittings as they entered the heads themselves..took about 30 minutes..
Re: what size oil restrictor? [Re: BILLYJAY] #469548
09/15/09 11:23 PM
09/15/09 11:23 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
#70 holley jet
1.39 9.85 - 137 mph
Re: what size oil restrictor? [Re: bigtimeauto] #469549
09/15/09 11:39 PM
09/15/09 11:39 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
I also just got T&d ONE SHAFT PER CYLINDER. tHEY CHANGED MY OILING THEY GOT ME CHEVY LIKE LIFTER THAT ARE GOING TO OIL THE TOP? HOW ARE YOU OILING?
DO I NEED TO RESTRICT OIL IF SO HOW?
Re: what size oil restrictor? [Re: hugo] #469550
09/15/09 11:58 PM
09/15/09 11:58 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
.050 to .075,if your using Indy external lines on the heads just tap the threads in the#3 fitting and use Holley jets.
Re: what size oil restrictor? [Re: moparniac] #469551
09/16/09 12:03 AM
09/16/09 12:03 AM
Trophy Winner
Trophy Winner
Call Scott and tell him i told you to call. He will take care of you.
http://www.parraceengines.com/
Re: what size oil restrictor? [Re: bigtimeauto] #469552
09/16/09 12:06 AM
09/16/09 12:06 AM
Trophy Winner
Trophy Winner
I did the nitrous jet set-up. Just put the fittings in the lathe, faced them, drilled the hole and was done. I put .059's in we'll see.
Bob I have the indy external line set up.
Thanks again guys
Re: what size oil restrictor? [Re: bigtimeauto] #469553
09/16/09 07:04 AM
09/16/09 07:04 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
post pic from way back.... however is this a T&D only thing....
Mopar Performance
Re: what size oil restrictor? [Re: bigtimeauto] #469554
09/16/09 05:42 PM
09/16/09 05:42 PM
N
n20mstr Offline
n20mstr  Offline
N
Thanks again guys
this is the best way in my opinon because now you can "jet" it very quickly to fine tune the oil up top. SO you gonna post up the HP you made on the dyno?? Ive been wondering what you been up to...its been an up and down season for me too, LOL
Re: what size oil restrictor? [Re: n20mstr] #469555
09/16/09 10:37 PM
09/16/09 10:37 PM
Trophy Winner
Trophy Winner
Thanks again guys
Yes the NOS jets worked out real good. Numbers you say? When i see you i'll tell you. You know I can't post what it makes on the internet.
Re: what size oil restrictor? [Re: bigtimeauto] #469556
09/16/09 10:39 PM
09/16/09 10:39 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
dude you have one of the baddest darts on the board.. if not the nicest....
Mopar Performance
Re: what size oil restrictor? [Re: moparniac] #469557
09/16/09 10:42 PM
09/16/09 10:42 PM
Trophy Winner
Trophy Winner
Thanks!
