i used the 64's that were in my Holley jet box..i wanted to use 55-60 but figured as long as i slowed down that massive oil flow and kept it in the pan the better off i was.. instead of tapping just the t-block in the block i tapped both fittings as they entered the heads themselves..took about 30 minutes..
