A body Front drum brakes acting strange #469475
09/15/09 08:47 PM
09/15/09 08:47 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Took my 72 Dart to Tucson on Friday,about an hour trip both ways depending the speed you drive and traffic on the road.
The car performed well,but for some reason Started to notice the front brakes acting strange. When you press the brakes,you can hear a "Clunk" and the car wants to pull hard left.Dont know if it matters but this is a manual 4 wheel drum brake car.
I can kinda guess what the pull is all about,and that maybe the brakes need adjusting? But the Clunk,whats that all about?
Guess I should just take the front drums off and see whats what huh?
Oh I almost forgot to ask,whats the proper torque spec for the castle nut on the front hub when reinstalling the drum?
Re: A body Front drum brakes acting strange [Re: SPWC] #469476
09/15/09 08:54 PM
09/15/09 08:54 PM
Pull that RF drum & see whats up
Re: A body Front drum brakes acting strange [Re: RapidRobert] #469477
09/15/09 09:26 PM
09/15/09 09:26 PM
SPWC Offline OP
SPWC  Offline OP
AAARGH...Pulled the drivers front drum,(thats where the pull was toward) and discovered a broken return spring.
It never ends with these old cars...does it? Well im off to go buy a hardware kit.
Re: A body Front drum brakes acting strange [Re: SPWC] #469478
09/15/09 09:52 PM
09/15/09 09:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It helps to do some diagnosis befroe posting questions. That way folks can give better heplful answers. It also means that in a lot of cases you won't have to post the simple questions in the first place.
