Radiator recored - now what to use for paint!?? #469204
09/15/09 04:05 PM
09/15/09 04:05 PM
Tennessee
WyleECoyote Offline OP
Tennessee
69,000 original mile car - all original.
I had to have the radiator recored.
I asked them not to paint it so I got it back bare naked.
I want to make it look "weathered" and 38 years old like it was before the recore.
What do you all think?
Flat black engine enamel and gray engine enamel lightly dusting one color and then the other??
Ideas?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Radiator recored - now what to use for paint!?? [Re: WyleECoyote] #469205
09/15/09 05:27 PM
09/15/09 05:27 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
You could just use Hi-Temp Flat Black, then pour dirty, rusty water over it when it's Hot, a few times.
Re: Radiator recored - now what to use for paint!?? [Re: D_C] #469206
09/15/09 10:02 PM
09/15/09 10:02 PM
Tennessee
Tennessee
I like the way you think! You know exactly what I'm trying to replicate - thanks for the idea.
Wile E. Coyote
Re: Radiator recored - now what to use for paint!?? [Re: WyleECoyote] #469207
09/15/09 10:16 PM
09/15/09 10:16 PM
D_C Offline
D_C  Offline
The potential "problem" with the gray spray-paint, is the possibility of it looking more like overspray or tiny-dot speckled. Granted, if still wet, it might blend-in with the black, but not sure.
The Flat Black High-Temp enamel should protect the radiator, and paint flattens as it ages.
Brown plus gray might look better if the Rusty-Old radiator Water technique doesn't get it done for you.
Good Luck with it.
Re: Radiator recored - now what to use for paint!?? [Re: D_C] #469208
09/15/09 10:50 PM
09/15/09 10:50 PM
SE Pa.
LimeliteAero Offline
SE Pa.
no need for the gray, just flat will look old and dirty in no time.
Re: Radiator recored - now what to use for paint!?? [Re: LimeliteAero] #469209
09/15/09 11:08 PM
09/15/09 11:08 PM
Tennessee
Tennessee
Roger that!
Will post pics to update for those that are trying to do the same.
Thanks!
Re: Radiator recored - now what to use for paint!?? [Re: WyleECoyote] #469210
09/15/09 11:44 PM
09/15/09 11:44 PM
You might want to spray the fins themselves w special radiator paint that transfers heat better than regular paint.
