Re: tuff 904
[Re: Ian]
#469009
09/15/09 03:39 PM
09/15/09 03:39 PM
Triple Threat
Renton Washington
What small block are you planning thats gonna be making 750-800 horses? Just curious.
Re: tuff 904
[Re: Ian]
#469011
09/15/09 05:51 PM
09/15/09 05:51 PM
Posts: 6,145 Melbourne , Australia
LA360
I hope you're planning on getting your wallet out alot, lol
If this is a race only deal, than I would be looking at: a 300M or Hy Tuff input and output shaft. An aluminium high/reverse drum with the big piston. A Griner Transbrake A roller rear support Alto Red Eagle frictions and Kolene steels Red lined solid bands
I am not sure if the factory steel plantaries will hold up at that weight, so a call to Pro Trans for straight cut gears maybe in order.
This would also be a high maintenance trans
If you are going to street drive it, build a 727
I am assuming Ian it was the trans I saw on the ground on the Heathcote website? Or did the diff go and take the trans out with it? AL.....
Alan Jones
Re: tuff 904
[Re: Ian]
#469014
09/15/09 11:49 PM
09/15/09 11:49 PM
Posts: 1,880 USA
Ron Silva
USA
Dave at Pro Trans built the 904 that was behind the 474 CI R3/W9 motor in my Demon. Only failure ever was a broken output shaft and that was after I put taller (3.91) gears in the rearend. Also, not his fault because they did not have a billet output shaft at the time (and still may not). I will have his trans behind the 501 when it goes in my car in a few months. Ron.
SRT DEMON ONE SEAT
Re: tuff 904
[Re: Ian]
#469016
09/16/09 02:53 AM
09/16/09 02:53 AM
LA360
Pro Trans don't have a website. TCS and A&A trans do which should give you an idea of what you're up for.
Was it a WAR case you broke? AL...
Alan Jones
Re: tuff 904
[Re: LA360]
#469021
09/16/09 11:02 PM
09/16/09 11:02 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
AL, i build the lot from diff ,auto , engine ,pipes etc pm me your number i call ya for chat one day thanks ian
