tuff 904 #469008
09/15/09 01:54 PM
09/15/09 01:54 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
car is 3500 lbs ,410 cub 904 ,5000 stall trans brake 3.9 lever,low gear set . and the rest is stock ,what do i need to make it last with 750-800 hp . 3.9 rear and 26/10
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: tuff 904 [Re: Ian] #469009
09/15/09 03:39 PM
09/15/09 03:39 PM
Renton Washington
Triple Threat Offline
Renton Washington
What small block are you planning thats gonna be making 750-800 horses? Just curious.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: tuff 904 [Re: Ian] #469010
09/15/09 04:35 PM
09/15/09 04:35 PM
Call or contact Dave Smith at Pro trans,661-940-7400
Re: tuff 904 [Re: Ian] #469011
09/15/09 05:51 PM
09/15/09 05:51 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I hope you're planning on getting your wallet out alot, lol
If this is a race only deal, than I would be looking at:
a 300M or Hy Tuff input and output shaft.
An aluminium high/reverse drum with the big piston.
A Griner Transbrake
A roller rear support
Alto Red Eagle frictions and Kolene steels
Red lined solid bands
I am not sure if the factory steel plantaries will hold up at that weight, so a call to Pro Trans for straight cut gears maybe in order.
This would also be a high maintenance trans
If you are going to street drive it, build a 727
I am assuming Ian it was the trans I saw on the ground on the Heathcote website? Or did the diff go and take the trans out with it?
AL.....
Alan Jones
Re: tuff 904 [Re: LA360] #469012
09/15/09 11:09 PM
09/15/09 11:09 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
the 904 bean good to date ,not broke a thing in the box yet, 727 is to big for the tunnel in the ap6 ,it was the 9 inch exploding its carrier
Re: tuff 904 [Re: Triple Threat] #469013
09/15/09 11:12 PM
09/15/09 11:12 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
410 indy headed and 200 shot of gas
Re: tuff 904 [Re: Ian] #469014
09/15/09 11:49 PM
09/15/09 11:49 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Dave at Pro Trans built the 904 that was behind the 474 CI R3/W9 motor in my Demon. Only failure ever was a broken output shaft and that was after I put taller (3.91) gears in the rearend. Also, not his fault because they did not have a billet output shaft at the time (and still may not). I will have his trans behind the 501 when it goes in my car in a few months.
Ron.
SRT DEMON ONE SEAT
Re: tuff 904 [Re: Ron Silva] #469015
09/15/09 11:57 PM
09/15/09 11:57 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks mate, i will give him a call ,have they a web site mate
Re: tuff 904 [Re: Ian] #469016
09/16/09 02:53 AM
09/16/09 02:53 AM
LA360 Offline
LA360  Offline
Pro Trans don't have a website. TCS and A&A trans do which should give you an idea of what you're up for.
Was it a WAR case you broke?
AL...
Alan Jones
Re: tuff 904 [Re: LA360] #469017
09/16/09 03:14 AM
09/16/09 03:14 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
std twin rib mate ,now its got all stange rear ,and shaft
Re: tuff 904 [Re: Ian] #469018
09/16/09 05:50 AM
09/16/09 05:50 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
Why not give Tony Brinkley a shot at it. Hes in Townsville and stocks all the griner gear and can access all the rest. Lucas with the indy engine in the black charger has a 904 behind it making similar power.
www.brinksperformance.com.au
Re: tuff 904 [Re: vc360] #469019
09/16/09 12:11 PM
09/16/09 12:11 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks mate i will have a chat with him
Re: tuff 904 [Re: Ian] #469020
09/16/09 06:05 PM
09/16/09 06:05 PM
LA360 Offline
LA360  Offline
Who built the Auto you have now?
AL....
Alan Jones
Re: tuff 904 [Re: LA360] #469021
09/16/09 11:02 PM
09/16/09 11:02 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
AL, i build the lot from diff ,auto , engine ,pipes etc
pm me your number i call ya for chat one day
thanks ian
Re: tuff 904 [Re: Ian] #469022
09/16/09 11:31 PM
09/16/09 11:31 PM
LA360 Offline
LA360  Offline
It's much better doing it yourself, you only have one person to blame if it craps itself!
AL...
Alan Jones
Re: tuff 904 [Re: LA360] #469023
09/17/09 01:42 AM
09/17/09 01:42 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks mate ,i can live with my mistakes ,its [Edited by Moparts - Family Friendly Site - Keep it clean] loads better than paying someone to do there half jobs on it and the GLORY is all mine
