Page 1 of 3 1 2 3
B-1 PSO Dyno Test - Updated Pictures #468841
09/15/09 12:11 PM
09/15/09 12:11 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline OP
P
SouthEast Michigan
I finally finished my 588 (4.500X4.625) with the PSO Heads. It has a Custom 55mm camshaft 285/300 at .050 with .954 lift and 15 to 1 compression. I used an old Mega block I have had for a while. I used the new Quick Fuel QFX 1050 carbs. John Marcella built the tunnel ram manifold. The Heads are the first ones I did a long time ago and are a little different than the improved ones we have now. I used a Peterson 5 stage dry oiling system with a Charlie’s pan. The oil pressure was too high for the RPM of the engine and we started moving the cam with positive results. The first pull from 6-7 thousand RPM it made 1099 HP. The Dyno starter failed and ended our day early; it was still making more power on every pull. I know there’s still 20HP there.
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468842
09/15/09 12:12 PM
09/15/09 12:12 PM
SouthEast Michigan
P
P
SouthEast Michigan
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468843
09/15/09 12:13 PM
09/15/09 12:13 PM
SouthEast Michigan
P
P
SouthEast Michigan
2
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468844
09/15/09 12:14 PM
09/15/09 12:14 PM
SouthEast Michigan
P
P
SouthEast Michigan
3
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468845
09/15/09 12:17 PM
09/15/09 12:17 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Nice! Great to see the wedge heads surpass 1100 HP!
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468846
09/15/09 12:18 PM
09/15/09 12:18 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
That's great... Good numbers..
Re: B-1 PSO Dyno Test [Re: 70dusterjohn] #468847
09/15/09 12:31 PM
09/15/09 12:31 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468848
09/15/09 12:35 PM
09/15/09 12:35 PM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
Who's valve covers are those? And do you sell them?
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468849
09/15/09 12:43 PM
09/15/09 12:43 PM
Western MA, +121 posts on old ...
sixpacstac Offline
super gas
sixpacstac  Offline
super gas
Impressive #'s!
Great looking piece, also!
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468850
09/15/09 12:54 PM
09/15/09 12:54 PM
Hemiroid Offline
Hemiroid  Offline
Looking good Pete! Going in the Bee?
Re: B-1 PSO Dyno Test [Re: Hemiroid] #468851
09/15/09 01:29 PM
09/15/09 01:29 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Fantastic!!
Maybe I don't need to buy that procharger after all
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468852
09/15/09 01:55 PM
09/15/09 01:55 PM
AndyF Offline
AndyF  Offline
Nice looking motor Pete.
Re: B-1 PSO Dyno Test [Re: AndyF] #468853
09/15/09 01:57 PM
09/15/09 01:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Good numbers for sure..I need to get me one of those intakes
Re: B-1 PSO Dyno Test [Re: PETE@BESTMACHINE] #468854
09/15/09 02:18 PM
09/15/09 02:18 PM
NC
440Jim Offline
440Jim  Offline
NC
1171 hp at 7800 rpm and still climbing at the end of the pull.
Re: B-1 PSO Dyno Test [Re: 440Jim] #468855
09/15/09 02:44 PM
09/15/09 02:44 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Great numbers. A Pro-charged motor could make that on pump gas, with a small hydraulic roller, without breaking a sweat.
Re: B-1 PSO Dyno Test [Re: Big B] #468856
09/15/09 03:05 PM
09/15/09 03:05 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Pick up 20 and you'll be right around 1200.
Awesome power for a straight head. I wonder what it would do with one of your new castings in a full max N/A effort???
Are you going to fix the dyno and run it again up to 8500 or so??? And is the A/F lean or is it just me???
Re: B-1 PSO Dyno Test [Re: jim sciortino] #468857
09/15/09 03:15 PM
09/15/09 03:15 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Nice numbers
So what were the head's flowing around??
Re: B-1 PSO Dyno Test [Re: jim sciortino] #468858
09/15/09 03:49 PM
09/15/09 03:49 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You wouldnt call this a max effort N/A effort?
Good numbers, nice going Pete..
Bob Coomer from Ky
Re: B-1 PSO Dyno Test [Re: Bob_Coomer] #468859
09/15/09 03:59 PM
09/15/09 03:59 PM
Trumbull,CT.
Trumbull,CT.
Bob Coomer from Ky
I've seen engines with 17+ compression, well over an inch lift and ring stacks from hell, insanely light cranks and bob weights, among other "tricks". I don't know whats in this engine other than whats listed and whats listed in not on kill. Plus he said the newer PSO head is a better deal....so no, I wouldn't call this max effort.
Killer, but not an "on the edge" deal.
Would youc call it a max build???
Re: B-1 PSO Dyno Test [Re: jim sciortino] #468860
09/15/09 05:07 PM
09/15/09 05:07 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I think N/A Pred and B1-TS engine are 1300hp +++ now.
Page 1 of 3 1 2 3
