Solid Lifter Cam "Clacking" #468679
09/15/09 08:16 AM
09/15/09 08:16 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I recently broke in my first solid lifter camshaft (Comp Cams .520 244/252) and using Crane 1.5 Gold rockers. All set up by engine builder.
I hear a lot of "clacking" going on in the engine. I broke in the cam with the proper oil/additives and all went well. Changed the oil after break in with Valvoline Racing 20/50 racing oil.
The engine seems fine, has plenty of power, just is a little noisy. Is this to be expected with solid lifter cams?
Thanks.
RS23L7 4-Speed
Re: Solid Lifter Cam "Clacking" [Re: Mopar_Mike] #468680
09/15/09 08:58 AM
09/15/09 08:58 AM
solid lifter cams and their valvetrains are noisy by nature. if in doubt about anything, check the valve lash to be sure all is okay internally.
Re: Solid Lifter Cam "Clacking" [Re: Mopar_Mike] #468681
09/15/09 12:52 PM
09/15/09 12:52 PM
Does it get quieter when it warms up? Did you reset the lash when it warmed up? What is the valve lash set at now? I ans well as many other racers and engine builders will tighten the lash up some to see if the motor will make more power as well as that will make them quieter, sometimes depending on the cam design and rockers used My street motor with a Comp Cams solid roller cam and harland Sharp rocker arms do not calack set at .024 intake and .024 exhaust hot
Re: Solid Lifter Cam "Clacking" [Re: Cab_Burge] #468682
09/15/09 01:06 PM
09/15/09 01:06 PM
Danville, NH
Danville, NH
When I picked up the engine the builder told me the lash was set at .018 This would be cold. I have not checked it hot.
I would say it gets louder when it warms up..?
I do not have the cam card, but I believe it suggests .016-.018 lash.
RS23L7 4-Speed
Re: Solid Lifter Cam "Clacking" [Re: Mopar_Mike] #468683
09/15/09 01:31 PM
09/15/09 01:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This sound right...
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Number: CCA-21-232-4
Cam Style: Mechanical flat tappet
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 244
Exhaust Duration at 050 inch Lift: 252
Duration at 050 inch Lift: 244 int./252 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 290
Advertised Duration: 282 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.540 exh. lift
Lobe Separation (degrees): 110
Camshaft Gear Attachment: 1-bolt
Intake Valve Lash: 0.016 in.
Exhaust Valve Lash: 0.018 in.
Computer Controlled Compatible: No
Grind Number: CRB XE282S-10
Re: Solid Lifter Cam "Clacking" [Re: Mopar_Mike] #468684
09/15/09 01:37 PM
09/15/09 01:37 PM
It is time to check it now before it has a chance to get worse, do you know how to set the lash and the proper procedure to do it? If not say so and we will help you do that, it is necessary to check the lash hot because that is the way the motor runs 95% of the time
