Solid Lifter Cam "Clacking"
#468679
09/15/09 08:16 AM
09/15/09 08:16 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I recently broke in my first solid lifter camshaft (Comp Cams .520 244/252) and using Crane 1.5 Gold rockers. All set up by engine builder.
I hear a lot of "clacking" going on in the engine. I broke in the cam with the proper oil/additives and all went well. Changed the oil after break in with Valvoline Racing 20/50 racing oil.
The engine seems fine, has plenty of power, just is a little noisy. Is this to be expected with solid lifter cams?
Thanks.
RS23L7 4-Speed
Re: Solid Lifter Cam "Clacking"
[Re: Mopar_Mike]
#468680
09/15/09 08:58 AM
09/15/09 08:58 AM
solid lifter cams and their valvetrains are noisy by nature. if in doubt about anything, check the valve lash to be sure all is okay internally.
[Re: Mopar_Mike]
#468683
09/15/09 01:31 PM
09/15/09 01:31 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I do not have the cam card, but I believe it suggests .016-.018 lash.
This sound right...
Brand: COMP Cams
Product Line: COMP Cams Xtreme Energy Camshafts
Part Number: CCA-21-232-4 Cam Style: Mechanical flat tappet Basic Operating RPM Range: 2,500-6,500 Intake Duration at 050 inch Lift: 244 Exhaust Duration at 050 inch Lift: 252 Duration at 050 inch Lift: 244 int./252 exh. Advertised Intake Duration: 282 Advertised Exhaust Duration: 290 Advertised Duration: 282 int./290 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.520 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540 in. Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.540 exh. lift Lobe Separation (degrees): 110 Camshaft Gear Attachment: 1-bolt Intake Valve Lash: 0.016 in. Exhaust Valve Lash: 0.018 in. Computer Controlled Compatible: No Grind Number: CRB XE282S-10
