Re: Gains switching to larger intake valve [Re: theclutcher] #468411
09/16/09 09:37 AM
09/16/09 09:37 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Probably no gain unless you unshroud the valve by machining the combustion chamber.
if that is shrouded, you can expect very little then bore size comes into play.
imo...
Anytime I've tried unshrouding the intake valve (straight wall side) on an
OEM head, it hurt flow. I haven't tried it on the RPM though.
That is interesting,
Have only seen the opposite.
Hmmmm..........3 notebooks full notes and a flow bench is pretty handy.
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468412
09/16/09 09:52 AM
09/16/09 09:52 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
imo...
cant argue with that, just the few Ive had experience with always picked up, big or small block when opening up that area.
wonder what the difference could be?
Re: Gains switching to larger intake valve [Re: theclutcher] #468413
09/16/09 10:04 AM
09/16/09 10:04 AM
S/ST 3040 Offline
S/ST 3040  Offline
Scott.....I know the OEM big block heads do like opening that
up, the more, the better, I understand but, it always screws
up the high lift flow on my small block heads.
Dwayne Porter and I discussed this once in conversation
as, we both found the same thing.
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468414
09/17/09 08:59 AM
09/17/09 08:59 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Hi Vic.
At what lifts you see the reduction?
Would not come into play too much if cam doesnt see time spent at that lift point.
wondering if plusses if any at low lift more than offset the loss at high point.
what have you seen?
Re: Gains switching to larger intake valve [Re: theclutcher] #468415
09/17/09 09:18 AM
09/17/09 09:18 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Hey Josh! Long time no talk!
I think switching to the 2.05 valve is more expensive/time consuming than the improvement you will see (valve job, cut seats, new valve, set up springs, intake gaskets, head gaskets, antifreeze, oil, etc).
I would concentrate on weight, particularly the hood where you will get a lot of weight off the nose.
Tell your dad "hi" for me!
Re: Gains switching to larger intake valve [Re: theclutcher] #468416
09/17/09 09:31 AM
09/17/09 09:31 AM
S/ST 3040 Offline
S/ST 3040  Offline
OEM SB Casting #974 Manley Pro-Flo 2.02" x 30º BC
.............BEFORE.........................................AFTER
.100"_____62.0____________________________62.4
.200"____127.3___________________________128.9
.300"____188.9___________________________192.1
.400"____241.8___________________________240.2
.500"____269.8___________________________268.0
.550"____268.0___________________________****
.600"____269.2___________________________266.2
.650"____269.9___________________________268.3
.700"____273.3___________________________268.3
**** - Turbulent/Noisy
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468417
09/17/09 09:34 AM
09/17/09 09:34 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Josh, just leave it alone, and get started on the Dart...
Taking over the World one win light at a time.
Re: Gains switching to larger intake valve [Re: TheOtherDodge] #468418
09/17/09 12:50 PM
09/17/09 12:50 PM
New Braunfels, TX
416challenger Offline OP
New Braunfels, TX
James- I figured since I was already going to be freshing the motor I would ask the question, but It sounds like it isn't a worth while investment. Now I just have to find a hood.
Curtis- The Dart isn't going to happen anytime soon, we just put Mackenzie is preschool.
