Re: Gains switching to larger intake valve
[Re: theclutcher]
#468411
09/16/09 09:37 AM
09/16/09 09:37 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Probably no gain unless you unshroud the valve by machining the combustion chamber.
if that is shrouded, you can expect very little then bore size comes into play. imo...
Anytime I've tried unshrouding the intake valve (straight wall side) on an OEM head, it hurt flow. I haven't tried it on the RPM though.
That is interesting, Have only seen the opposite.
Hmmmm..........3 notebooks full notes and a flow bench is pretty handy.
[Re: S/ST 3040]
#468412
09/16/09 09:52 AM
09/16/09 09:52 AM
Posts: 2,172 Ohio
theclutcher
Ohio
cant argue with that, just the few Ive had experience with always picked up, big or small block when opening up that area. wonder what the difference could be?
[Re: theclutcher]
#468415
09/17/09 09:18 AM
09/17/09 09:18 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Hey Josh! Long time no talk!
I think switching to the 2.05 valve is more expensive/time consuming than the improvement you will see (valve job, cut seats, new valve, set up springs, intake gaskets, head gaskets, antifreeze, oil, etc).
I would concentrate on weight, particularly the hood where you will get a lot of weight off the nose.
Tell your dad "hi" for me!
