Not such a good track day. #468143
09/14/09 06:16 PM
09/14/09 06:16 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
My brother and I went to Cecil to run the N/SS class yesterday as it was the rain date for Saturday. They also ran the AMI class and some FAST (Supercars) class and the regular bracket car along woth the Jr dragsters. So it was very packed and they said we only get one time run. And only 4 cars showed up for the N/SS class. But on my only time run I messed up and launched in second gear so I just aborted the run. When they called our 4 class cars for eliminations my brothers 64 Fury would not back up and lost reverse. So I go up and dail and 11.55 as thats what I ran there in early June. After my burnout they tell me to back out and shut it off. Seems my thermostat housing gaket decided to start leaking and I was dripping anti-freeze. So I never did get a clean run on my car yesterday as I went and fixed the leak but it was getting late and I was tired so we headed home. At least nothing major broke. I plan to go to a T & T in a month or so as it got very hot yesterday and I want to wait for it to cool down some. Ron
Re: Not such a good track day. [Re: 383man] #468144
09/14/09 07:30 PM
09/14/09 07:30 PM
Hemiroid Offline
Hemiroid  Offline
That sucks Ron, but at least nothing serious broke. I hate it when you do all it takes to get to the track and that damn Murphey and his laws show up
This kinda brings up another question I've been thinking about. Should we be running anti-freeze at the track?
I too have a street car like yours that I drive a lot and run anti-freeze in as it lubes the water pump, raises the boiling point and resists corrosion. It also greases down a dragstrip when a failure happens. Just wondering what are peoples opinions on this?
Sorry for the highjack Ron
Re: Not such a good track day. [Re: Hemiroid] #468145
09/14/09 07:34 PM
09/14/09 07:34 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Here is what they call for up here.... if you drive your car TO the track. Anti freeze is acceptable.
If it comes in on a trailer and found to have anti freeze in it. Your out.
However I was at the track one time when they were bringing it around for racers.... my cooler was sitting outside the RV, was my wifes first time at the track (we just started dating), I woke up and the cooler was frozen solid....LOL
Re: Not such a good track day. [Re: Garceau] #468146
09/14/09 10:41 PM
09/14/09 10:41 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Practically no one, especially the OP, is deliberately trying to create an unsafe condition. But having said that, I am of the opinion that antifreeze has no business being near the racetrack. Especially on older cars that don't seal as well as new ones do. If you have a car that you run on the street and take to the track occasionally, just put petcocks in place of the block drain plugs. This way you can easily drain the block and radiator and get the antfreeze out. When you get the car back home, just put the stuff you drained out right back in. It's really not that hard and might save someone(or yourself) a lot of grief.
Same holds true for the power steering. Best to at least leave the belt off so that if you have a failure of a hose or the pump, you won't spray the ps fluid all over the place and cause a major catastrophe.
Think and be considerate....
MB
Re: Not such a good track day. [Re: Garceau] #468147
09/14/09 10:48 PM
09/14/09 10:48 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
That is a ridiculous rule..
I have seen pristine 15 second cars that are perfect in every respect trailered to the track, and I have also seen pretty fast, cobbed up, shitttboxes drive to the track.
Get the point??
MB
Re: Not such a good track day. [Re: HPMike] #468148
09/14/09 11:19 PM
09/14/09 11:19 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I am sure that every street car at the track drains his anti-freeze and puts water in just to race. And then changes it back when they get back home. Ron
Re: Not such a good track day. [Re: 383man] #468149
09/14/09 11:29 PM
09/14/09 11:29 PM
Ron,just run distilled water/water wetter mix during the warm months,and switch to a anti-freeze/water mix when ya put the '63' away for the winter. Your car will run cooler,and be safer if you spring a leak at the track! RandyB
Re: Not such a good track day. [Re: HPMike] #468150
09/14/09 11:29 PM
09/14/09 11:29 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Antifreeze should be a big no-no at the track. If you are really worried about your water pump seals, there are water pump lubes and other additives that can be used that don't snot the track up if you have a leak. It gets real old to have to wait 45 min for a track cleanup after a hose blows on a car because some dorf thinks that straight A/F cools better. If you have cooling issues, fix them on your own time, not everybody elses track time. At least straight water evaps almost instantly and isn't as likely to put you into the wall. Hoses break, head gaskets fail, and freeze plugs pop out - don't make it worse and snot the track up with A/F. I think it should be checked at tech - no A/F or no race...
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Not such a good track day. [Re: Evil Spirit] #468151
09/15/09 12:21 PM
09/15/09 12:21 PM
P
Paul_Fancsali Offline
P
I have been at the track on days where the high was 33 degree's and yes we raced. The point of running water Vs antifreeze is ridiculous what about engine oil or trans fluid. Back in day's we ran street cars after one of the fast ones took a dump on the track.Regardless the majority of the ones taking a dump are the fast cars not the street cars, the track should have the equipment to clean it right. Period Not lets run street to soak up the oil. I pay the same as everyone else!
Re: Not such a good track day. [Re: Evil Spirit] #468152
09/15/09 01:07 PM
09/15/09 01:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Well said
Too many leakers out there, NO A/F
Oil is way easier to cleanup than anti freeze!!!!!!!
Re: Not such a good track day. [Re: Paul_Fancsali] #468153
09/15/09 01:23 PM
09/15/09 01:23 PM
organ
maximum entropy Offline
organ
is antifreeze that much worse than oil or trans fluid or gear lube? our cars are filled with the slickest substances known to man. how about synthetics? i run antifreeze in my car. i drive it to the track, and i'm NOT going to run water only. i check and maintain my cooling system to the best of my human abilities, and say my prayers. if i get banned, oh well, it is a street car.
Re: Not such a good track day. [Re: maximum entropy] #468154
09/15/09 02:40 PM
09/15/09 02:40 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
That's a poor analogy...
On several accounts. For one, the motor/trans won't run without oil so you have to run oil. Also, aside from a pressurized source, the engine likely won't pour oil. Your cooling system will just as easily run with water as it would antifreeze. Also many more opportunities for a failure. Heater hoses, core plugs, rad hoses, the radiator, etc.
Also, the rear usually won't pour gear oil all over the track unless it explpoded. Even a bad pinion seal won't drip much oil, as it would if you popped a rad hose and dumped 3 gallons of coolant on the track.
MB
Re: Not such a good track day. [Re: HPMike] #468155
09/15/09 03:07 PM
09/15/09 03:07 PM
organ
organ
thank you.
Re: Not such a good track day. [Re: maximum entropy] #468156
09/15/09 03:13 PM
09/15/09 03:13 PM
Most of the break downs leaks ect..at my track are caused by STREET cars especially the frontwheel drive "broom stick axles cars"..anti freeze is a no no,i can't remember how many times racing was stopped because someone dump it on the track
Re: Not such a good track day. #468157
09/15/09 03:42 PM
09/15/09 03:42 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
What if you drain the radiator and there is still antifreeze in the block? Just thought id see some of your guys opinions on that.
Re: Not such a good track day. [Re: 69B3GT] #468158
09/15/09 04:23 PM
09/15/09 04:23 PM
P
P
Frankly the tech guy's would actually look at some of the junk at thetrack they would certainly ban it. I had a Mustang that ran ine the upper 11s shear his 4 WHEEL Studs I stopped with less then 20-30 ft from a complete T bone,lets not worry about antifreeze when you have a 9 sec car running wheel adapters shear them right off and send flying problem is they do not check those cars after the beginning of the season. Oh well I can go on but what the use why not just ban everything and close up the tracks period
Re: Not such a good track day. [Re: Paul_Fancsali] #468159
09/15/09 06:32 PM
09/15/09 06:32 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
There is no way anti-freeze is harder to clean up the oil or trans fluid. Its a hell of alot easier to clean anti-freeze in my shop the oil is.
And your making a big deal out of something that is not the reason for this thread. I was simply stating that I had a bad luck day and never even thought there would be so much crying because I have some anti-freeze in my street car. I have no problem with the tech guy backing me out and not letting me make that pass. He did his job and may have saved me from big trouble. I was just stating that my luck was not so good that day. I feel that oil and trans fluid and P/S fluid can be as much or more dangerous to worry about leaking then anti-freeze IMO.
So I had a bad day as I had a small leak at the line. Dont matter what fluid it was its just the fact that I had a leak. The guy also had an attitude to me as he came to me and said .........yesterday you leak trans fluid and today coolant. Then I told him I did not leak any trans fluid yesterday because I WAS NOT HERE YESTERDAY ! Then he says am I sure. Ah yea I do think I know where I was yesterday. Then he says ......oh it must have been another red car. Ron
Re: Not such a good track day. [Re: 383man] #468160
09/15/09 06:35 PM
09/15/09 06:35 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Way to stir the pot Ron
I agree coolant is easier to clean than oils. I occasionally work at our track.
codfish
Re: Not such a good track day. [Re: 383man] #468161
09/15/09 07:27 PM
09/15/09 07:27 PM
Hemiroid Offline
Hemiroid  Offline
Again Ron sorry for the hijack, I should have started my own thread. I too run anti-freeze, that's why I asked. So all of you haters flame me , not Ron!
Re: Not such a good track day. [Re: Hemiroid] #468162
09/15/09 07:34 PM
09/15/09 07:34 PM
organ
organ
i'm an accomplice- sorry. or a conspirator, if you will. not a co-conspirator. there's no such thing.
