valve springs
#467720
09/14/09 06:52 AM
09/14/09 06:52 AM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
My valve springs only have seat pressure of 111 lbs. Cam card says I should have 145 lbs.Eledbrock RPM heads with a 643 lift cam. What valve springs should I go with ? What is the part #? Big block 440 ( 496)
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: valve springs
[Re: caper]
#467723
09/14/09 10:31 AM
09/14/09 10:31 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Stock heads are 1.880 installed height.
Since Edelbrock heads have NO top cut on the valve job........the last set I did, ended up with .060" shims under the 'stamped cup".
A little juggling shims and keepers should get 1.950" pretty easy.
Re: valve springs
[Re: caper]
#467724
09/14/09 12:30 PM
09/14/09 12:30 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
I think Edelbrock says there springs on the RPM heads are only good to .600 lift I like to see 150+ and 325 to 375 lbs. open on both flat tappet cams, hydraulic and solids Try shimming them first, make sure you have at least .060 to coil binnd, check every one of them individually Replace them if needed with a better spring from Comp, Lunati, Isky
Re: valve springs
[Re: marvo451]
#467726
09/14/09 03:55 PM
09/14/09 03:55 PM
caper
I got a hold of Scott Brown , a new set on the way. Thanks for the replys, Sheldon
