My valve springs only have seat pressure of 111 lbs. Cam card says I should have 145 lbs.Eledbrock RPM heads with a 643 lift cam. What valve springs should I go with ? What is the part #? Big block 440 ( 496)
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
