Going to discbrakes
#467667
09/14/09 05:48 AM
09/14/09 05:48 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
I have my 66 Dart ready to go now, it will be a family bracket car that my wife and I will drive. But it does not feel really safe with the 9 inch drums up front. I don't have a lot of money to use for this car so I need some help deciding on what setup to use. So what is the cheapest discbrake kit around. I don't have any scrapyards here with american car that I can take parts from. Thanks
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Going to discbrakes
[Re: MrSixpack]
#467669
09/14/09 08:36 AM
09/14/09 08:36 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I like my Aerospace brakes. Member LilDemon is a dealer for them and gives discounts to moparts members. CHIP
[Re: MrSixpack]
#467671
09/14/09 09:51 PM
09/14/09 09:51 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
There is no disc brake conversion in your existing bolt pattern except the expensive and hard to find parts for factory discs. Perhaps you can find some Euro-spec, 5-on-100mm, rotors that can be mounted to your existing hubs and then make some caliper mounts that will bolt to your existing spindles? Shipping to Sweden will be high for heavy parts, you can forget about low cost, of course it's all relative to your own budget. The cheapest parts would be the '73-up F,M,J,B-body spindles and rotors with different upper control arms or ball joint adapters. You'd also need different lower ball joints, '73-'76 A-body spec. Good luck.
[Re: MrSixpack]
#467674
09/15/09 01:30 PM
09/15/09 01:30 PM
Thigh-Gap Junction
I do want to get the 4.5 bc in front to, I have a new 8 3/4 with 4.5 ready installed
Maybe your budget is a little higher than I inferred from your original post. I sent you a PM.
