Re: Six Barrel vs Single 4 barrel
[Re: Randy514]
#467304
09/13/09 11:47 PM
09/13/09 11:47 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Six Packs are cool, but Ive never seen one run with a good single plain manifold and a good 4150 or dominator for that fact with those kind of cubic inches/application. Ive never had any experiance with a Team G manifold, but a victor or M1 single plane with a good 4150 like a 950HP or 1000HP or a 4500 dominator would no doubt make more power. Six packs are awesome on street cars or cars in classes that HAVE to use stock carbs. Other than those two variables, single plane, four barrel is the way to go.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: Randy514]
#467307
09/14/09 06:21 AM
09/14/09 06:21 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Seeing is believing. I love the look, the sound and the performance of a sixpack. Here's a comparison of a sixpack and a four barrel on my 493" pulled 682 horsepower with 3-2's, ported Edelbrock aluminum manifold and small port Indy EZ heads, with a 550 lift hydraulic cam spinning at only 5500 rpm. Here's the article on it from Hughes. http://www.hughesengines.com/TechArticles/13dynotest684hp500cid6pack4bbljcross012007.php
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Cab_Burge]
#467308
09/14/09 06:24 AM
09/14/09 06:24 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Six paks are for SS and Stk , street apps too . But for a bracket race car , for the sake of ease of tune ability do yourself a big favour and go 4 bbl. Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Randy514]
#467309
09/14/09 07:56 AM
09/14/09 07:56 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Sixpackgut has always run 6 packs on his challenger (493" RB motor), but he did test a GOOD single 4 setup once and it slowed his car down. If I recall correctly he tested an Indy single plane w/ a 950 HP Holley against his well tuned six pack setup. He is not using a stock six pack intake though. When he did the test I can't remember which 6 pack manifold he was using, it was either the Weiand SS hi-rise 6 pack or a modified tunnelram with a six pack top on it. CHIP
