update new best low gear added #466958
09/13/09 11:17 AM
09/13/09 11:17 AM
St. Louis Mo.
10 o to go Offline OP
"Happy Don"
"Happy Don"
St. Louis Mo.
put in low gear and super sprag in 727
took some preload out and set car little higher
Raced at benton IL 8th mile
best et their was 6.39 4.13 1.39 average 60ft
9/12/09
(1)1.41 4.07 6.337 best now
(2)1.40 4.07 6.336 best
(3)1.35 4.01 6.328 lift win
(4)1.34 4.00 6.277 bye run
(5)1.33 got out of groove abort
So the 418 4.30 gear is grunting and moving.
Can't wait to get to GIR to get my liscence now. The beast shows it can run 9.95 on PAPER
Don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: update new best low gear added [Re: 10 o to go] #466959
09/14/09 06:18 AM
09/14/09 06:18 AM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
fred thats a A&A low gear set
2.74 1st gear , 1.54 2nd gear .
I believe stock is 2.45 on 1st gear
Don
Re: update new best low gear added [Re: 10 o to go] #466960
09/14/09 07:13 AM
09/14/09 07:13 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
That has be a much better feeling than what I saw in back of your truck at MMW last year .
Re: update new best low gear added [Re: FY1TA] #466961
09/14/09 06:25 PM
09/14/09 06:25 PM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
Its been a fun year so far been more laid back trying little things still has more left .
between the low gear and twicking the supsinsion pickup .12 in the 8th and 6in 60ft
going to GIR TUESDAY TnT
then get the new slicks for Black sunday race and ready for MMW.
looks like i can run S/p ,PRO, 10.0 shootout
come by shack a moparts member hand or a.
DON
Re: update new best low gear added [Re: 10 o to go] #466962
09/14/09 07:55 PM
09/14/09 07:55 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Don, how big of a tire are you running? the old cuda would 1.36 60 with 3.91 gear and 28" street radail. I went from 430 to the 3.91 and picked up. 416 SB 8" 727 , no low gear...Phill
Re: update new best low gear added [Re: 9 Sec Phill] #466963
09/14/09 08:48 PM
09/14/09 08:48 PM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
Phil the tires are 11.5,29.5 w=13.5,30.5 shift at 6600 went thru traps 6800 before low gear change .
looking for 9.90s tues nite .hope weather is their .
don
Re: update new best low gear added [Re: 10 o to go] #466964
09/14/09 08:55 PM
09/14/09 08:55 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
What are the pros and cons of a low gear set
Mopar Performance
Re: update new best low gear added [Re: moparniac] #466965
09/14/09 10:25 PM
09/14/09 10:25 PM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
I'm not any expert on it just have used them on my 318 in the 90s ran 12.50s in this car 340s ,360s with 904s then went back to 727s with low gear .Some say not to use with a lite car Whats THAT ,magic weight .I use it with a brake at 4400 leave. 1.39 at GIR this year best see what TUES does .MAYBE more will chime in .
Anybody have thought what does low gear change in the rear gear i thought possably 4.30 to 4.56s .
don
Re: update new best low gear added [Re: 10 o to go] #466966
09/14/09 10:26 PM
09/14/09 10:26 PM
Is the set you used a straight cut or helical?
Re: update new best low gear added [Re: Cab_Burge] #466967
09/14/09 10:46 PM
09/14/09 10:46 PM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
CAB helical from A&A those straight are real pricy
don
Re: update new best low gear added [Re: 10 o to go] #466968
09/15/09 02:06 AM
09/15/09 02:06 AM
don
Yeah, I know I have freinds who run the all out Pro Trans 904 in his NHRA stockers $$$ It is a very good way to increase the ET and MPH per $ spent
Re: update new best low gear added [Re: Cab_Burge] #466969
09/15/09 04:45 PM
09/15/09 04:45 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Where is our Tuesday night update? Did you get the nine?
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: update new best low gear added [Re: Irun5snd8th] #466970
09/15/09 04:58 PM
09/15/09 04:58 PM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
eric key word tonite humid ,cloudy,73 degrees, should hook just dont know yet ,got new slicks coming thursday get them in time for the UBDRA sat sun cooler weather also then .hows the shock deal might look at them when your here MMW
don
