Anyone run late main brgs in and early block? 360 SB #466385
09/12/09 02:19 PM
09/12/09 02:19 PM
Gainesville,FL
goldmember Offline OP
Gainesville,FL
I realize the early 70-73 360 list a different main bearing than those 74 up. The thrust bearing diameter is larger on the later bearing. In the past I haven't questioned this only installed the bearing that matched the year being built. Today I have a 360 for a friend on the stand and no place to get the early style bearing. I installed the later main bearing set that I had on the shelf and can find no problems with this. Any engine builders have any input? Thanks to any who have done this or maybe found a problem that I'm overlooking?
Re: Anyone run late main brgs in and early block? 360 SB [Re: goldmember] #466386
09/12/09 02:27 PM
09/12/09 02:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
don't know but I seen 2 360s on craigslist for $100. here's the guys number if he still has them. 904-742-0907
Re: Anyone run late main brgs in and early block? 360 SB [Re: Quicktree] #466387
09/12/09 02:30 PM
09/12/09 02:30 PM
Gainesville,FL
Gainesville,FL
Where would I put 2 more? Back to the original question. LOL
Re: Anyone run late main brgs in and early block? 360 SB [Re: goldmember] #466388
09/12/09 02:40 PM
09/12/09 02:40 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I thought the width of the thust flange to flange was slightly different? Like .004 Not sure. But you should check the thrust clearance real close and see what you have. It may be too much or too little. Factory spec is .002 to .007 with max allowable being .010
SRT DEMON ONE SEAT
Re: Anyone run late main brgs in and early block? 360 SB [Re: Ron Silva] #466389
09/12/09 02:49 PM
09/12/09 02:49 PM
Gainesville,FL
Gainesville,FL
It is the diameter thats listed as different. I've installed and set the thrust,dial indicator claims .005" clearance,can't figure out what problem I'm overlooking?
Re: Anyone run late main brgs in and early block? 360 SB [Re: goldmember] #466390
09/12/09 03:07 PM
09/12/09 03:07 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If the block is machined big enough in dia for the later bearing to fit, then there should be no problem.
Re: Anyone run late main brgs in and early block? 360 SB [Re: dartman366] #466391
09/12/09 05:39 PM
09/12/09 05:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I don't know about 360's but I suspect the differance is the same as early vs late big block bearings & this photo should explain the change...
Thanks to Brandon @ 440 Source for the photo...
Bearing width & diameter are the same, it's the thrust face diameter that is larger...
Re: Anyone run late main brgs in and early block? 360 SB [Re: 1_WILD_RT] #466392
09/12/09 06:27 PM
09/12/09 06:27 PM
Gainesville,FL
Gainesville,FL
Right. The late(wide) thrust bearing fit's well inside the relief area in the block and cap. Therefore my question.
Re: Anyone run late main brgs in and early block? 360 SB [Re: goldmember] #466393
09/12/09 09:01 PM
09/12/09 09:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'd like to hear it from a professional engine builder but it seems like it is Ok to me...
Re: Anyone run late main brgs in and early block? 360 SB [Re: goldmember] #466394
09/12/09 09:53 PM
09/12/09 09:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the bearing fits and the crank spins then you don't have an issue , on a big block there is no way you would get the large thrust bearing in an early block as the picture above shows .
Re: Anyone run late main brgs in and early block? 360 SB [Re: goldmember] #466395
09/12/09 10:10 PM
09/12/09 10:10 PM
what are the actual part #'s of the bearings your looking at?
Re: Anyone run late main brgs in and early block? 360 SB #466396
09/12/09 10:16 PM
09/12/09 10:16 PM
Gainesville,FL
Gainesville,FL
The bearings I have on hand are FM 4999m.
Re: Anyone run late main brgs in and early block? 360 SB [Re: goldmember] #466397
09/12/09 10:25 PM
09/12/09 10:25 PM
i like the 4948MA bearing better. either should work fine. it just depends on if you want 1/2 or 3/4 groove
Re: Anyone run late main brgs in and early block? 360 SB #466398
09/12/09 10:27 PM
09/12/09 10:27 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Same for small blocks>
No problem running the narrow thrust bearing on the wide later blocks but you can't run the later wide thrust in the early blocks.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Anyone run late main brgs in and early block? 360 SB [Re: MoparforLife] #466399
09/12/09 10:39 PM
09/12/09 10:39 PM
Gainesville,FL
Gainesville,FL
"but you can't run the later wide thrust in the early blocks."
Have you tried it or just repeating something you heard?What problem did you find? I still haven't found the issue in doing this.
Re: Anyone run late main brgs in and early block? 360 SB #466400
09/12/09 10:44 PM
09/12/09 10:44 PM
Gainesville,FL
Gainesville,FL
I'm not worried about a 3/4 groove on this deal,it's not mine and it won't make enough power or rpm to be a threat to itself.Thanks
