Help needed updating a 426 hemi with a roller cam #466292
09/12/09 11:35 AM
09/12/09 11:35 AM
usa
DLP4 Offline OP
DLP4  Offline OP
usa
I'm interested in installing a roller cam in a street only hemi car but I'm having trouble finding all the info I need to do what I want.
Does anybody make a "tame" solid roller cam for a street driven hemi?
Do I need a bronze intermediate gear if I can find a street cam? Or do I always need bronze?
How do I install a cam button? (The shim is probably self-explanitory but I should ask about installing that too.)
I had a Comp Cams 557/540 that I was happy with until the lobes went away. Something in that performance range or even a little less would be good.
thanks
Re: Help needed updating a 426 hemi with a roller cam [Re: DLP4] #466293
09/12/09 11:56 AM
09/12/09 11:56 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I've never seen a "tame" roller for a Hemi, I have a couple of the "smaller" ones that are available, and they are still around .650 lift and are pretty long on duration. I doubt if there is one available....I don't see the market for one.
You will need the bronze gear if it is a billet cam (most rollers are).
I still use the same old Crane cam button I've used for many years....I just tap it into the front of the camshaft in between the three bolts.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Post deleted by Defbob [Re: DLP4] #466294
09/12/09 12:01 PM
09/12/09 12:01 PM
Re: Help needed updating a 426 hemi with a roller cam #466295
09/12/09 12:15 PM
09/12/09 12:15 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Crane had a few Street Roller cams for the Hemi on their website before going under. I don't know if the resurfaced company still makes cams for cars.
Floyd Lippencott IV
Re: Help needed updating a 426 hemi with a roller cam [Re: mr_340] #466296
09/12/09 12:23 PM
09/12/09 12:23 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Check into pushrod oiling too when buying lifters. Some of us use cams with a little more lift and were gauling pushrods. It can be an issue, its not always an issue, but I believe you need oil through lifters to do it, so why not get those either way.
Re: Help needed updating a 426 hemi with a roller cam [Re: Dragula] #466297
09/12/09 12:32 PM
09/12/09 12:32 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Contact Tim at FHO.
http://www.forhemisonly.com/
He can give you all the answers and set you up with what you will need.
Re: Help needed updating a 426 hemi with a roller cam [Re: The Shadow] #466298
09/12/09 01:18 PM
09/12/09 01:18 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Crower makes a small solid roller. A member on this board had one in his Hemi car and loved it. I think he put around 15000 miles on it before he sold the car.
Re: Help needed updating a 426 hemi with a roller cam [Re: Dragula] #466299
09/12/09 01:55 PM
09/12/09 01:55 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I would go stright to comp cams .They helped me put together a package with roller cam,roller lifters and valve springs.I am using the 848 amc style lifter with the EDM oiling,also sent oil up the exhaust pushrods to a solid adjuster.A cam in the low 600,s would be real easy and give you plenty of grunt What are your intentions with this build,are you assembling it yourself and what kinda car??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Help needed updating a 426 hemi with a roller cam [Re: DLP4] #466300
09/12/09 02:10 PM
09/12/09 02:10 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I went to Cam Dynamics for my custom grind roller cam and I'm very happy with it. I run power brakes so I needed something that wouls allow for enough vacuum for the power booster....My cam is .611 Intake and .545 exhaust and 245@50... I went with Morell lifters and yes you will need a bronze gear. The car ran a best of 12.1 @ 116, 4000 lb car and a 4 speed. I know it has mid 11s in her, I just have to get the suspension dialed in. Go roller and don't look back, it's well worth the extra $$$$$....and it works well on the street.
71 440-6 4spd & 69 Hemi 4spd
Re: Help needed updating a 426 hemi with a roller cam [Re: DLP4] #466301
09/12/09 05:00 PM
09/12/09 05:00 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Bush the lifter bores.
Otherwise you can and probably will run into some issues, especially if it's an original(old) casting that's been handed around a lot over the years.
MB
Re: Help needed updating a 426 hemi with a roller cam [Re: HPMike] #466302
09/12/09 05:03 PM
09/12/09 05:03 PM
hemi-itis Offline
hemi-itis  Offline
MB
Would you provide pressurized oil to the lifters??
Re: Help needed updating a 426 hemi with a roller cam [Re: hemi-itis] #466303
09/12/09 05:15 PM
09/12/09 05:15 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
MB
yep.
Re: Help needed updating a 426 hemi with a roller cam [Re: HPMike] #466304
09/12/09 05:30 PM
09/12/09 05:30 PM
hemi-itis Offline
hemi-itis  Offline
MB
yep.
Mike,how large on opening would you use in the "BUSH"
Re: Help needed updating a 426 hemi with a roller cam [Re: hemi-itis] #466305
09/12/09 05:44 PM
09/12/09 05:44 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I run an .080" orifice.
Too many original blocks and some of the newer ones as well have very inconsistent lifter bores.
MB
Re: Help needed updating a 426 hemi with a roller cam [Re: HPMike] #466306
09/12/09 06:16 PM
09/12/09 06:16 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
Here's one I got from Crowler.
If your using a mechanical pump make sure you specify that.
Idled nice, lots of vacuum.
Re: Help needed updating a 426 hemi with a roller cam [Re: six-barrel] #466307
09/12/09 09:53 PM
09/12/09 09:53 PM
usa
DLP4 Offline OP
DLP4  Offline OP
usa
six-barrel - did the custom grind have a premium charge? I see Crower has an off-the-shelf cam with similar specs. Did you use Crower lifters?
I need a valve spring compressor. Is there anything around that will work with the heads on or off?
Re: Help needed updating a 426 hemi with a roller cam [Re: DLP4] #466308
09/12/09 09:57 PM
09/12/09 09:57 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
If you want to do it right I would take the heads off and get the valve tip and spring heights correct...also clean up the valves and seats. You're gonna want to degree the cam as well...
Re: Help needed updating a 426 hemi with a roller cam [Re: hemi_doug] #466309
09/12/09 10:30 PM
09/12/09 10:30 PM
usa
DLP4 Offline OP
DLP4  Offline OP
usa
If you want to do it right I would take the heads off and get the valve tip and spring hights correct...also clean up the valves and seats. You're gonna want to degree the cam as well...
Thanks for good advice. I've got the heads off but since I need to buy a spring compressor I thought it would be nice to have one that would allow me to pull the springs with the heads on if I need it later. But it looks like this would be two different tools
Re: Help needed updating a 426 hemi with a roller cam [Re: six-barrel] #466310
09/12/09 10:33 PM
09/12/09 10:33 PM
never heard of them. do they make cams?
Re: Help needed updating a 426 hemi with a roller cam #466311
09/13/09 12:05 AM
09/13/09 12:05 AM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
Okay, okay, a typo,
Yes I went with CROWER lifters as well. Bushed the lifter bores as well.
