Pertronix coil and ballast resistor. #465325
09/10/09 11:05 PM
09/10/09 11:05 PM
Gator73 Offline OP
Gator73  Offline OP
I have a Pertronix Flame Thrower coil and the instructions state to bypass the ballast resistor. Just wanted to ask here and be sure that this is something that must be done and will be safe for my electrical system or if it can be run with the ballast without any ill effects. The car is street driven and uses a stock mopar electronic distributor with orange ECU. Thanks in advance.
Re: Pertronix coil and ballast resistor. [Re: Gator73] #465326
09/10/09 11:14 PM
09/10/09 11:14 PM
scratchnfotraction Offline
I use the pertronix point conversion in my 85 truck,every thing is hooked up and working fine with the flame thrower 40,000 volt coil
on the 68 Dart I used the shell of the BR to use a #10 wire solderd to the ends and by passed the BR to get a full 12 volts
on the electroinic conversion I did with the points dizzy,on stock engines,you get a slight better advance curve on the dizzy and the only reson to unhook the ecu is in case it is shorted out,,that would cause problems..I am working on somthing not broke..so its good and can be left hooked up...but this is all from under the shade tree and results will vary,along with opinions
run what ya brung..I do
Re: Pertronix coil and ballast resistor. [Re: scratchnfotraction] #465327
09/12/09 11:31 AM
09/12/09 11:31 AM
Gator73 Offline OP
Gator73  Offline OP
Anybody else have any advice and opinions on whether to run the full twelve volts to the coil or keep the stock setup and run it through the ballast resistor?
Re: Pertronix coil and ballast resistor. [Re: Gator73] #465328
09/12/09 11:42 AM
09/12/09 11:42 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Run full 12v to the coil. The Pertronix coil has internal resistance built into it. Between the coil and the BR you're going to end up with 6/7 volts at the coil. If you want to verify your voltage at the coil with the BR in place, Pertronix has instructions for a "loaded" voltage test on their site. If you can't find it I can walk you through it.
I also modified my BR with a #8 wire as mentioned above in post #2.
Re: Pertronix coil and ballast resistor. [Re: scratchnfotraction] #465329
09/12/09 01:56 PM
09/12/09 01:56 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
how do you like the petronix set up so far? do you have the ignitor II?
Re: Pertronix coil and ballast resistor. [Re: Dakota_Don] #465330
09/12/09 02:05 PM
09/12/09 02:05 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I would like to know cost wise how it fairs
up against MSD?
Snap your neck, mega G-force launch, is all I want!
Re: Pertronix coil and ballast resistor. [Re: BDS871Cuda] #465331
09/12/09 02:53 PM
09/12/09 02:53 PM
Gator73 Offline OP
Gator73  Offline OP
I'm not using the complete Ignitor system, just the flame thrower coil. I use a stock mopar distributor that has been recurved along with the orange ECU.
Re: Pertronix coil and ballast resistor. [Re: 64Post] #465332
09/12/09 07:27 PM
09/12/09 07:27 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: Pertronix coil and ballast resistor. [Re: Lefty] #465333
09/13/09 07:42 AM
09/13/09 07:42 AM
I have had mine for over 9 yrs and not a single problem and has plenty of fire,never a miss fire and turns right up to 6200 rpms
its all I will run,and much cheaper than msd set ups
