How many amps does a trans brake solenoid draw?
#464943
09/10/09 02:16 PM
09/10/09 02:16 PM
Posts: 1,417 Chicago, IL
blownEFI
Chicago, IL
Trying to figure out what size fuse to use in my trans brake circuit. The wires on the solenoid look so tiny (22 guage??) it makes me think it can't be drawing much current. Does anyone know?
"These go to eleven", Nigel Tufnel
Re: How many amps does a trans brake solenoid draw?
[Re: B G Racing]
#464946
09/10/09 06:52 PM
09/10/09 06:52 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
the instructions that came with my Tranz Act brake says the solinoid draws 7 amps and to use a 16 gauge wire or larger with a 25 amp fuse
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: MR_P_BODY]
#464949
09/10/09 08:00 PM
09/10/09 08:00 PM
blownEFI
Chicago, IL
I have a JW Ultraglide but I don't know who makes the solenoids they use. The wires are so teency small, maybe even 24 or 26 gauge little white wires, just doesn't seem like they could handle much current.
[Re: Leon441]
#464951
09/11/09 01:34 AM
09/11/09 01:34 AM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Just checked a 2 wire Glide solenoid the other day while doing some electrical work on a car. 10 amps, don't recall the make, TCI or Trans Specialties maybe. I agree with just using a 30 amp fuse or breaker to keep from burning everything up in case of a dead short.
