High horsepower 727 or? #463889
09/09/09 11:44 AM
09/09/09 11:44 AM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
I am wondering what tranny the high horsepower guys are using. We are looking at making 1500hp on our next build, can a 727 be built to handle that level and if so what parts would you use? Alternative transmission suggestions are welcome as well, we are not committed to anything in that department yet. Thanks
Re: High horsepower 727 or? [Re: nitrousr] #463890
09/09/09 11:50 AM
09/09/09 11:50 AM
Netherlands
72Challenger Offline
Netherlands
Depends on the weight of your ride too I guess. My buddy runs a 727 behind a approx. n/a 1200hp hemi in a 70 Roadrunner @ 3700lbs running high 8's. And so far it hasn't given a cramp.
Give John (CRT) a call to be sure.
Re: High horsepower 727 or? [Re: 72Challenger] #463891
09/09/09 11:56 AM
09/09/09 11:56 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Bruno type set up with a lenco. Thats where they incorporate the lenco with a converter. However if street driven this may not be an ideal set up.
Lots of good trans out there to handle that kind of power.
I personally dont know of any 727s behind anything with that type of power.
Re: High horsepower 727 or? [Re: 72Challenger] #463892
09/09/09 11:57 AM
09/09/09 11:57 AM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Go Lenco, or Bruno, if nothing else, the ease of picking your gear ratios.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: High horsepower 727 or? [Re: nitrousr] #463893
09/09/09 01:28 PM
09/09/09 01:28 PM
Stratford,Ct
7sec.cuda Offline
7sec.cuda  Offline
Stratford,Ct
we run 1500hp with a n/a hemi with a 727 with no issues
Post deleted by Defbob [Re: Slingshot383] #463894
09/09/09 01:46 PM
09/09/09 01:46 PM
Re: High horsepower 727 or? #463895
09/09/09 01:49 PM
09/09/09 01:49 PM
regina sask
N
nitrousr Offline OP
nitrousr  Offline OP
N
regina sask
7sec from your sig i can assume you are running a dynamic trans? The powerglide option came up but were concerned about vehicle weight (approx 3400 pounds)
Re: High horsepower 727 or? [Re: nitrousr] #463896
09/09/09 06:10 PM
09/09/09 06:10 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Get over the friggen weight issues and a Glide. You know where that statement came from? Mopar boards!
With that much HP it doesnt matter what the car will weigh.
You could go TH 400 if your worried about the weight and the gearing.
Buddy ran 8.2s in 3900lb car with a glide.
Re: High horsepower 727 or? [Re: Garceau] #463897
09/09/09 06:13 PM
09/09/09 06:13 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I personally would go with a Powerglide. Like Garceau said, the weight thing is BS. I have a glide in a 3200+ish car and have no problems at all.
In contrast to that statement, have you considered a Pro-Flite?
Re: High horsepower 727 or? [Re: sixpakdodge] #463898
09/09/09 06:31 PM
09/09/09 06:31 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
A good glide is your best bang for the buck. I recommend a Mike's transmissions ultimate glide.
Re: High horsepower 727 or? [Re: nitrousr] #463899
09/09/09 07:41 PM
09/09/09 07:41 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
Yep, powerglide.
"These go to eleven", Nigel Tufnel
Re: High horsepower 727 or? [Re: 7sec.cuda] #463900
09/09/09 10:09 PM
09/09/09 10:09 PM
ky
68roadrunner Offline
ky
what rear gear and 1st trans gear with that much power dont seem like you need much starting line ratio?
Re: High horsepower 727 or? [Re: blownEFI] #463901
09/09/09 10:13 PM
09/09/09 10:13 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
A chevie friend has ran several Turbo charged combinations. He has several transmission options. He has tried the glide several times but says he cannot build boost quick enough with the glide. He often jokes and say he does not make enough power for a glide. He uses a turbo 400 with aftermarket ratio's. He has sense went to a crank driven blower and still runs the 400 but takes off in second now.
I would have no problem running a 727 with your combo. Tranzact has a new gear ratio available. No matter what you do if running a 727 I would recommend running a 1" spacer between the engine and transmission to allow room for a 1" deeper torque converter. I found when switching to a powerglide that the extra 1" in dept of the chevie derived converters is the secret of why these chevie transmissions seem to have so much popularity in the high HP ranks. If doing it all over I would still have a 727 in my car and possible with a stock ratio 2.44 first gear. Something to consider if running a 3 spd behind a turbo would be to have the 1st to 2nd gear change shifted in relation to boost and not RPM. Just a thought.
Leon
Post deleted by Defbob [Re: Leon441] #463902
09/09/09 11:25 PM
09/09/09 11:25 PM
Re: High horsepower 727 or? #463903
09/10/09 01:48 AM
09/10/09 01:48 AM
AB
E
Efidart Offline
Efidart  Offline
E
AB
I just sold my 727 from behind my turbo'd 572.
Thought it would be a good idea to get rid of it before I broke it.
Went to an extreme automatics Turbo Glide, best of both worlds with the capability to handle whatever my engine can make.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: High horsepower 727 or? [Re: Efidart] #463904
09/10/09 04:29 AM
09/10/09 04:29 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
glide here too,
Re: High horsepower 727 or? [Re: nitrousr] #463905
09/10/09 05:56 AM
09/10/09 05:56 AM
Utah
topbrent Offline
topbrent  Offline
Utah
I have been trying to learn about turbo setups of late.
After too much time spent on the various turbo oriented forums, it is interesting to see that there are so many cars that have switched over to glides to exploit the the turbo loading/spooling effect. Many of those cars have gone way down(numerically) in rear gear also.
Some switched from their 3(-4-5-6) speeds for the spooling, some for traction woes, others for parts carnage / reliability.
At 1500 hp, it would seem you should have plenty of power to run a PG.
Get a 'glide with a brake, a two-step limiter, use a good converter.
Overall, this is cheaper, easier and probably the most safe.
Re: High horsepower 727 or? [Re: SG duster] #463906
09/10/09 06:11 AM
09/10/09 06:11 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
I'm going glide behind my 468-turbo motor.
My thoughts behind it were:
1.A lot of people use them and build them so parts & service/repairs are easy to come by
2.The taller 1st gear will absorb some of the initial shock of a Turbo Motor to the car and tires coming off the line.
3. Price of course
4. Less shifting
I got a heck of a package deal on a used but freshened up set-up.
Take a look at ATI's line up of PG's that come with warranties.
