Whats your weight??? #463539
09/08/09 11:07 PM
09/08/09 11:07 PM
Finally a HUSKER again
Moparnut426 Offline OP
My buddy just weighed his 65 Belvy with a 360, 905, and 8-3/4 in it. It weighed just at 3200 with interior. He used his scales he uses on his late odel every week. He has NEVER weighed over/under what is allowed.
Does that sound right??
What DO your cars weigh in Street form
I have never weighed my demon, but Im guessing 3000lbs..
Kasey
Re: Whats your weight??? [Re: Moparnut426] #463540
09/08/09 11:19 PM
09/08/09 11:19 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
My big block duster is 3580 with me.. My 67 Coronet was 3950 with me.. That seems light to me.. Could be wrong...
Re: Whats your weight??? [Re: 70dusterjohn] #463541
09/08/09 11:21 PM
09/08/09 11:21 PM
Its pretty rough, Not filled with rust, but its a street/strip car with no hood, and him out of it. Cody is probly 200lbs, and with him, and a hood, and a good trunk floor it is probably 3500lbs.
Re: Whats your weight??? [Re: 70dusterjohn] #463542
09/08/09 11:23 PM
09/08/09 11:23 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I don't know how you'd get a duster to weight that much and the coronet sounds heavy too. I'm guessing your not 350lbs?
Re: Whats your weight??? [Re: Moparnut426] #463543
09/08/09 11:26 PM
09/08/09 11:26 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
My duster with no fiberglass and me in it is 3070lbs. I'm 200lbs. Small block,iron heads, no lightening.
Re: Whats your weight??? [Re: goldmember] #463544
09/08/09 11:29 PM
09/08/09 11:29 PM
Deerfield, Ohio
Deerfield, Ohio
Full interior, roll bar, or cage. heater, all the bells and whisles radio ect.. Now my dart was 3220 with me.. only has a glass hood..and no I'm not 350 yet.. 220 on a good day.. I am will to work on 350 though.. LOL
Re: Whats your weight??? [Re: 70dusterjohn] #463545
09/08/09 11:39 PM
09/08/09 11:39 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
A cage will add to the total and the big block will as well. I guess I figured the poster had a small block and no cage.
Re: Whats your weight??? [Re: goldmember] #463546
09/08/09 11:39 PM
09/08/09 11:39 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Goldmember, you better check your scales...I have never heard of a car that light without extreme lightening. My 72 dart weighs 3500 with me, aluminum headed small block, full exhaust, and a 75 pound moly roll bar. My buddies 68 dart is lightened a bunch with fiberglass hood, bumpers, and brackets, aluminum interior, one race bucket seat, lexan, aluminum headed 383, and it weighs 3020 with driver. I am sure he could get it under 2900 with more fiberglass, and a moly cage in place of the mild steel one.
I know a belvedere is probably a little lighter than a sport fury, but my big block four speed 65 weighed 4200 with me in it.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Whats your weight??? [Re: 70dusterjohn] #463547
09/08/09 11:42 PM
09/08/09 11:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My 63 with the 440 goes about 3530 without me and about 3700 with me. Its a full interior stock body with rollbar and frame connectors. My sons Dart with a 400 in it goes about 3550 with him in the car and he is about 180 which makes his Dart just about 3370 without him. Ron
Re: Whats your weight??? [Re: DconD100] #463548
09/08/09 11:43 PM
09/08/09 11:43 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd check the scales,but they are NHRA scales and 2 small block dusters on the same scales were within 10lbs. Both small blocks,both all steel and the only difference is the amount of fuel in the tank.Yes it sounds better to up your weight to make you think your making some real HP,but I'll stick to reality.
Re: Whats your weight??? [Re: goldmember] #463549
09/08/09 11:46 PM
09/08/09 11:46 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
The only place I have ever weighed a car is on the NHRA scales at Bandimere. Still haven't seen a 3000 unlightened car that isn't a 4 banger.
Having said that, just because I haven't seen it doesn't mean it doesn't exist...It wouldn't be the first time I was incorrect! Maybe cars weigh more at this elevation?
Re: Whats your weight??? [Re: DconD100] #463550
09/08/09 11:51 PM
09/08/09 11:51 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Mine has been on the Memphis Motorsports park and Gainesville raceway scales.Your welcome to borrow mine if you like. Come pick it up and leave a deposit.
Re: Whats your weight??? [Re: Moparnut426] #463551
09/08/09 11:59 PM
09/08/09 11:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have had a number of A bodys with both BB and SB in them, 3050 with the BB and roll bar with two poly race seats, light weight rims and tires, no heater, radio or back seat was pretty common on several Dusters and one 1969 Dart GTS 1967 to 1969 Barracuda fastbacks where a little heivier EDIT: BTW, my current 1971 Duster with a fibreglas front bumper and race hood weighs right at 3200 LBs with out me in it, it has the heater, radio, stock 1973 front bucket seats, extra insulation under the carpet and above the head liner .083 chome moly six point roll bar, sub frame connectors, RJ ladder bars with aluminum coil overs, stock gas tank full and two fairly big batterys in the trunk, light weight race rims and tires, 8 3/4 with a 35 spline spool and axles, 400 BB with Eddy heads and a Best Machine aluminum radiators, Hooker A body fenderwell headers with a three inch full length exhaust sytem with Magna flow muffs mounted at the rear bumper and no X or H pipe
Re: Whats your weight??? [Re: Cab_Burge] #463552
09/09/09 12:02 AM
09/09/09 12:02 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
3650 w/me in it
Re: Whats your weight??? [Re: DconD100] #463553
09/09/09 08:34 AM
09/09/09 08:34 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
71 Duster.......no heat, no A/C, no back seat, no cage, no fiberglass
Factory bench seat, iron head 340, aluminum intake, headers, full exhaust, 727, 8 3/4", steel wheels
Weighed 2920 lbs empty (not sure on fuel level)
Roughly 3090 lbs. with me in it.
Re: Whats your weight??? [Re: S/ST 3040] #463554
09/09/09 09:16 AM
09/09/09 09:16 AM
Hemiroid Offline
Hemiroid  Offline
My '65 Belvedere 6 cly 3 speed stick weighed 3209 all stock. I've weighed a lot of dusters, never seen one all stock/steel at 2800 lbs.
Re: Whats your weight??? [Re: Moparnut426] #463555
09/09/09 09:24 AM
09/09/09 09:24 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
On MIR's digital scales my Challenger weighed 3755#s w/ me (210#s) and a 3/4 full tank of gas.
That's a full interior (except for the back seat) w/ rollbar, frame connectors, aluminum heads / intake / w-p housing, manual steering (saves almost 40#s over a power-steering setup), a complete 3" exhaust to the rear bumper, T/A-style fiberglass hood, and some misc. things removed (e.g. bumper reinforcement brackets).
Yep, it's heavy... which is why I nicknamed it the MoPig years ago.
Re: Whats your weight??? [Re: BradH] #463556
09/09/09 10:01 AM
09/09/09 10:01 AM
Az
Crizila Offline
Crizila  Offline
Az
I NV all you guys. 4130 w/driver and 1/2 tank of fuel - ugh!
Fastest 300
Re: Whats your weight??? [Re: Crizila] #463557
09/09/09 11:11 AM
09/09/09 11:11 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Some weights of vehicles I've owned w/o driver:
70 Swinger /6 auto Full tank 3,150
71 Super Bee 340/4speed full tank 3,680
79 Aspen sport wagon 318/auto full tank 3,760
97 Ram 1500 4x4 full tank 5,150
70 Imperial 1/4 tank 5,050
72 Imperial 1/2 tank 5,250
66 Coronet wagon 383 (gutted) 1/8 tank 3,120
66 Coronet wagon 426 Hemi (gutted) full tank 3,300
Re: Whats your weight??? [Re: Shaker223] #463558
09/09/09 12:20 PM
09/09/09 12:20 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
My '81 AMC Spirit - Dodge 360, 904, 9"Ford, all steel panels, full interior, all but windshield is lexan. 2800lbs w/o driver 1550 front, 1250 rear. Unfortunately, driver is "chubby"....REALLY CHUBBY...
Free advice and worth every penny...
Factory trained Slinky rewinder.........
