Re: Whats your weight???
[Re: goldmember]
#463546
09/08/09 11:39 PM
09/08/09 11:39 PM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
Goldmember, you better check your scales...I have never heard of a car that light without extreme lightening. My 72 dart weighs 3500 with me, aluminum headed small block, full exhaust, and a 75 pound moly roll bar. My buddies 68 dart is lightened a bunch with fiberglass hood, bumpers, and brackets, aluminum interior, one race bucket seat, lexan, aluminum headed 383, and it weighs 3020 with driver. I am sure he could get it under 2900 with more fiberglass, and a moly cage in place of the mild steel one.
I know a belvedere is probably a little lighter than a sport fury, but my big block four speed 65 weighed 4200 with me in it.
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
[Re: 70dusterjohn]
#463547
09/08/09 11:42 PM
09/08/09 11:42 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My 63 with the 440 goes about 3530 without me and about 3700 with me. Its a full interior stock body with rollbar and frame connectors. My sons Dart with a 400 in it goes about 3550 with him in the car and he is about 180 which makes his Dart just about 3370 without him. Ron
[Re: goldmember]
#463549
09/08/09 11:46 PM
09/08/09 11:46 PM
DconD100
Colo Springs, CO
The only place I have ever weighed a car is on the NHRA scales at Bandimere. Still haven't seen a 3000 unlightened car that isn't a 4 banger. Having said that, just because I haven't seen it doesn't mean it doesn't exist...It wouldn't be the first time I was incorrect! Maybe cars weigh more at this elevation?
[Re: Moparnut426]
#463551
09/08/09 11:59 PM
09/08/09 11:59 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
I have had a number of A bodys with both BB and SB in them, 3050 with the BB and roll bar with two poly race seats, light weight rims and tires, no heater, radio or back seat was pretty common on several Dusters and one 1969 Dart GTS 1967 to 1969 Barracuda fastbacks where a little heivier EDIT: BTW, my current 1971 Duster with a fibreglas front bumper and race hood weighs right at 3200 LBs with out me in it, it has the heater, radio, stock 1973 front bucket seats, extra insulation under the carpet and above the head liner .083 chome moly six point roll bar, sub frame connectors, RJ ladder bars with aluminum coil overs, stock gas tank full and two fairly big batterys in the trunk, light weight race rims and tires, 8 3/4 with a 35 spline spool and axles, 400 BB with Eddy heads and a Best Machine aluminum radiators, Hooker A body fenderwell headers with a three inch full length exhaust sytem with Magna flow muffs mounted at the rear bumper and no X or H pipe
[Re: DconD100]
#463553
09/09/09 08:34 AM
09/09/09 08:34 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
71 Duster.......no heat, no A/C, no back seat, no cage, no fiberglass
Factory bench seat, iron head 340, aluminum intake, headers, full exhaust, 727, 8 3/4", steel wheels
Weighed 2920 lbs empty (not sure on fuel level)
Roughly 3090 lbs. with me in it.
[Re: Moparnut426]
#463555
09/09/09 09:24 AM
09/09/09 09:24 AM
BradH
On MIR's digital scales my Challenger weighed 3755#s w/ me (210#s) and a 3/4 full tank of gas. That's a full interior (except for the back seat) w/ rollbar, frame connectors, aluminum heads / intake / w-p housing, manual steering (saves almost 40#s over a power-steering setup), a complete 3" exhaust to the rear bumper, T/A-style fiberglass hood, and some misc. things removed (e.g. bumper reinforcement brackets). Yep, it's heavy... which is why I nicknamed it the MoPig years ago.
[Re: BradH]
#463556
09/09/09 10:01 AM
09/09/09 10:01 AM
Posts: 7,506 Az
Crizila
Az
I NV all you guys. 4130 w/driver and 1/2 tank of fuel - ugh!
Fastest 300
[Re: Shaker223]
#463558
09/09/09 12:20 PM
09/09/09 12:20 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
My '81 AMC Spirit - Dodge 360, 904, 9"Ford, all steel panels, full interior, all but windshield is lexan. 2800lbs w/o driver 1550 front, 1250 rear. Unfortunately, driver is "chubby"....REALLY CHUBBY...
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#463559
09/09/09 12:25 PM
09/09/09 12:25 PM
Posts: 705 Michigan
Hemiroid
I have that same problem
[Re: goldmember]
#463560
09/09/09 12:29 PM
09/09/09 12:29 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I'd check the scales,but they are NHRA scales and 2 small block dusters on the same scales were within 10lbs. Both small blocks,both all steel and the only difference is the amount of fuel in the tank.Yes it sounds better to up your weight to make you think your making some real HP,but I'll stick to reality.
I also have doubts of the reality there. I am in the 2900 area with glass hood and frt bumper, no interior, heater or wiper motor. Also all crash bars in doors gone and the shock mountings and reinforcement for the bumpers gone on my Duster. I only weigh 135 soaking wet with my winter clothes on so don't get much over 3000 in race weight.
[Re: Moparnut426]
#463561
09/09/09 06:36 PM
09/09/09 06:36 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
72 Dart, heater/AC/wipers/and back seat taken out. No fiberglass. All Iron small block. All Glass, no lexan. Race ready with full 5 gallon fuel cell.
3475 with my 300 lb. butt in it on Bristol Dragway's digital scales.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: fasteddie]
#463562
09/09/09 06:48 PM
09/09/09 06:48 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
71 Scamp with small block and alum heads and 904 street car with steel wheels #3300 no driver
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: fasteddie]
#463563
09/09/09 06:52 PM
09/09/09 06:52 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
most A bodies are not as lite as people think mine has a full tube chassis all aluminum interior full fiberglass front clip,deck lid,and bumpers aluminum heads,radiator, and its 2745 with driver its 2961
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Moparnut426]
#463565
09/09/09 07:27 PM
09/09/09 07:27 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
My '73 Duster is 3,500 pounds with me in it, and I am not that heavy. Iron headed small block, headers, aluminum intake, 727 trans, 8 3/4, all metal body, big chrome bumpers, full interior. My '76 Dart is 3,400 without driver. A bodies aren't always that light.
[Re: 9secondsatellite]
#463570
09/09/09 08:44 PM
09/09/09 08:44 PM
Posts: 9,827 MI, usa
dvw
MI, usa
76 Volare,340,iron heads,roots blower,subframe connecters,1 3/4" roll bar,weld wheels,3" exhaust,manual steering and brakes,stock interior. 3890w/me,3710 empty. I know, I can't believe it weighs that much either. I've weighed it many different times and places. Always 3850-3890 depending on fuel load. All OE equipment in dash including a/c evaporator and heater.It's amazing that it's gone 11.05@124.Doug
[Re: WILD BILL]
#463571
09/09/09 08:51 PM
09/09/09 08:51 PM
'69 GTX,440,727,8 3/4,full interior,6-point roll bar,aluminum wheels,18 lb. lift-off hood. 3500 lbs. w/o me, 3730 with. RandyB
[Re: dvw]
#463572
09/09/09 08:55 PM
09/09/09 08:55 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
My 67 coronet was 3580 with me on the scale at vegas. I weighed the exhaust when I took it off and it was 52 lbs, so I guess now race weight, all it, is about 3530. Full cage, two poly seats, all factory glass, wiper motor removed, carpeted interior.
[Re: G_bob]
#463573
09/09/09 09:05 PM
09/09/09 09:05 PM
Posts: 753 San Diego, CA
brktracr
super street
super street
San Diego, CA
My Duster, round tube back half, fiberglass doors, hood, trunk and bumpers. Glass front and rear window. Stock front half with a World big block. Weighs in at 3130#.
1.298 60 ft
6.001 1/8 mile
114 mph
9.52 1/4 mile
140.87 mph
@ 3110 lbs
[Re: brktracr]
#463575
09/09/09 09:30 PM
09/09/09 09:30 PM
Posts: 622 ct
jkgtx
ct
3800 with me....needs a diet
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
