383 shift points ?? #463331
09/08/09 08:14 PM
09/08/09 08:14 PM
Pennsylvania
proshiftcharger Offline OP
Pennsylvania
Specs:
383 30 over
10.5 comp
509 hyd cam
torker 2 intake
700 street avenger carb
906 heads stock
stock rocker arms
stock crank
stock rods
727 Automatic
shift kit
3800 stall speed
430 gears
28 x 9 slicks
Whats should the shift point be for this combo to achieve optimal et ??
thanks
Doug
Re: 383 shift points ?? [Re: proshiftcharger] #463332
09/08/09 08:19 PM
09/08/09 08:19 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Re: 383 shift points ?? [Re: moparguy7074] #463333
09/08/09 08:25 PM
09/08/09 08:25 PM
Johnstown, Ohio
fast383duster Offline
mopar addict
mopar addict
Johnstown, Ohio
I shift mine with almost the exact specs @ 5800
Ryan Goodin S/Pro B386 High Speed Graphix T-shirts, Signs and More! www.highspeedgraphix.com
Re: 383 shift points ?? [Re: fast383duster] #463334
09/08/09 09:32 PM
09/08/09 09:32 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I shift my street version at 6500 (xe284) and the track version sees 7-7200 but has been as high as 8200(with a BIG shot).
Both run stock block/crank/rods.
and rod bolts.
Re: 383 shift points ?? [Re: RemCharger] #463335
09/08/09 10:58 PM
09/08/09 10:58 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Used to shift mine at 6800, at the stripe- 6500
Re: 383 shift points ?? [Re: proshiftcharger] #463336
09/08/09 11:21 PM
09/08/09 11:21 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I shift mine at 6500,almost the same combo as yours.
Nautilus Racing-
Re: 383 shift points ?? [Re: proshiftcharger] #463337
09/09/09 12:01 AM
09/09/09 12:01 AM
Specs:
383 30 over
10.5 comp
509 hyd cam
torker 2 intake
906 heads stock
stock rocker arms
stock crank
stock rods
727 Automatic
shift kit
3800 stall speed
430 gears
28 x 9 slicks
thanks
Doug
My , go find out No two combinations or tachs are exactly the same
Re: 383 shift points ?? [Re: Cab_Burge] #463338
09/09/09 08:39 AM
09/09/09 08:39 AM
Pennsylvania
Pennsylvania
Thanks for the input guys.
I have to admit I had no idea this combo could still make power over 6000 rpms with all its stock components.
thanks again,
Doug
