Suggestions for belt driven oil pumps (non dry sump) #462861
09/08/09 02:51 AM
09/08/09 02:51 AM
Las Vegas NV
moparmanjames Offline OP
Las Vegas NV
Hey guys I've got some problems with my new chassis in the Duster. The stock big block oil pump is in the way of the steering linkage now that I am running a rack and pinion steering.
Anyone know of a decent and somewhat inexpensive external oil pump kit that I can run? Thanks
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: moparmanjames] #462862
09/08/09 05:29 AM
09/08/09 05:29 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I had the same issue. I went with a different rack and pinion where the shaft was horizontal with the ground and the steering linkage under the oil pump.
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: moparmanjames] #462863
09/08/09 10:30 AM
09/08/09 10:30 AM
AndyF Offline
AndyF  Offline
There are belt driven oil pumps for sale. Just set it up like a dry sump with a block plate and a drive mandral and everything. I think Moroso and Peterson have pumps, probably a few other places also.
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: moparmanjames] #462864
09/08/09 12:35 PM
09/08/09 12:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is it the filter it crashes into or is it the pump,
could go with a remote filter
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: MR_P_BODY] #462865
09/09/09 10:13 AM
09/09/09 10:13 AM
Las Vegas NV
Las Vegas NV
It's the pump housing, thanks.
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: Bigcube] #462866
09/09/09 10:16 AM
09/09/09 10:16 AM
Las Vegas NV
Las Vegas NV
I already bought my rack but could you send me some info like pics and part #s? Thanks.
Maybe I could return the rack for a different one.
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: moparmanjames] #462867
09/09/09 10:32 AM
09/09/09 10:32 AM
Hemiroid Offline
Hemiroid  Offline
Peterson makes a single stage belt driven pump that works well.
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: Hemiroid] #462868
09/09/09 10:42 AM
09/09/09 10:42 AM
Las Vegas NV
Las Vegas NV
Thanks I'll look into it.
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: moparmanjames] #462869
09/09/09 10:57 AM
09/09/09 10:57 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
First rack was a Wilwood. The shaft for the column came out with an up and to the left angle and went directly into the oil pump.
New rack is a stilletto. The steering shaft is horizontal with the ground and perpendicular to the rack.
Pic with the motor out
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: Bigcube] #462870
09/09/09 01:39 PM
09/09/09 01:39 PM
Las Vegas NV
Las Vegas NV
Thanks BigCube, you wouldn't have a part # for the rack would you? and maybe a link where to buy one, I did a search and didn't come up with a whole lot. Thanks Bro
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: moparmanjames] #462871
09/09/09 03:06 PM
09/09/09 03:06 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Check with S&W race cars, they are a dealer for the narrow stiletto rack used on dragsters. I don't have a part number but they only had one model for a door car. It was setup for 24" center to center frame rails. There was a little extra fabrication needed because it does not come with any type of rod ends or ball and socket. I have piece of hex alum that is threaded with right and left ends. Then there are to heims per side and and toe is adjusted just like it would be with a sleeve and tie rod ends. Their number is 1-800-523-3353
Another choice is VPrace cars... here's a link
http://www.vpracecars.com/userimages/VPRC08PG10.pdf
Re: Suggestions for belt driven oil pumps (non dry sump [Re: moparmanjames] #462872
09/09/09 08:40 PM
09/09/09 08:40 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Petersen Wet/Vac combo pump or a Stock Car Products pump
AL......
Alan Jones
Re: Suggestions for belt driven oil pumps (non dry sump) [Re: Bigcube] #462873
09/15/09 05:29 PM
09/15/09 05:29 PM
Las Vegas NV
Las Vegas NV
Which oil pump is that? Very cool!
