Re: Suggestions for belt driven oil pumps (non dry sump)
[Re: moparmanjames]
#462862
09/08/09 05:29 AM
09/08/09 05:29 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I had the same issue. I went with a different rack and pinion where the shaft was horizontal with the ground and the steering linkage under the oil pump.
[Re: moparmanjames]
#462864
09/08/09 12:35 PM
09/08/09 12:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hey guys I've got some problems with my new chassis in the Duster. The stock big block oil pump is in the way of the steering linkage now that I am running a rack and pinion steering. Anyone know of a decent and somewhat inexpensive external oil pump kit that I can run? Thanks
Is it the filter it crashes into or is it the pump, could go with a remote filter
[Re: MR_P_BODY]
#462865
09/09/09 10:13 AM
09/09/09 10:13 AM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
It's the pump housing, thanks.
[Re: Bigcube]
#462866
09/09/09 10:16 AM
09/09/09 10:16 AM
moparmanjames
Las Vegas NV
I already bought my rack but could you send me some info like pics and part #s? Thanks.
Maybe I could return the rack for a different one.
[Re: moparmanjames]
#462869
09/09/09 10:57 AM
09/09/09 10:57 AM
Bigcube
Upstate NY
First rack was a Wilwood. The shaft for the column came out with an up and to the left angle and went directly into the oil pump. New rack is a stilletto. The steering shaft is horizontal with the ground and perpendicular to the rack. Pic with the motor out
[Re: Bigcube]
#462870
09/09/09 01:39 PM
09/09/09 01:39 PM
moparmanjames
Las Vegas NV
Thanks BigCube, you wouldn't have a part # for the rack would you? and maybe a link where to buy one, I did a search and didn't come up with a whole lot. Thanks Bro
[Re: moparmanjames]
#462871
09/09/09 03:06 PM
09/09/09 03:06 PM
Bigcube
Upstate NY
Check with S&W race cars, they are a dealer for the narrow stiletto rack used on dragsters. I don't have a part number but they only had one model for a door car. It was setup for 24" center to center frame rails. There was a little extra fabrication needed because it does not come with any type of rod ends or ball and socket. I have piece of hex alum that is threaded with right and left ends. Then there are to heims per side and and toe is adjusted just like it would be with a sleeve and tie rod ends. Their number is 1-800-523-3353 Another choice is VPrace cars... here's a link http://www.vpracecars.com/userimages/VPRC08PG10.pdf
[Re: Bigcube]
#462873
09/15/09 05:29 PM
09/15/09 05:29 PM
moparmanjames
Las Vegas NV
Which oil pump is that? Very cool!
