Backup light engagement? #462801
09/07/09 11:08 PM
09/07/09 11:08 PM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
I replaced the backup switch on my 4speed Cuda.
Reverse light on the dash only engages if I push the shifter in reverse a little more.
Is this just a matter of adjusting the linkage rod?
Shawn 70 AAR
Re: Backup light engagement? [Re: ehbody] #462802
09/07/09 11:45 PM
09/07/09 11:45 PM
was that why you replaced it? I would adj the rev rod correctly & see if that takes care of it.
Re: Backup light engagement? [Re: RapidRobert] #462803
09/08/09 12:06 AM
09/08/09 12:06 AM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
Replaced because it was leaking, but it had the same problem before.
Shawn 70 AAR
Re: Backup light engagement? [Re: ehbody] #462804
09/08/09 12:14 AM
09/08/09 12:14 AM
I am not familiar w sticks but is there any way to screw it in a bit more so the plunger will get depressed further.
Re: Backup light engagement? [Re: RapidRobert] #462805
09/08/09 12:42 PM
09/08/09 12:42 PM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
Nope. Tight up and a paper gasket.
My original switch did not have this issue, but it broke, then I got MP replacement, and after 10years it leaked, now I got another MP replacement.
Shawn 70 AAR
Re: Backup light engagement? [Re: ehbody] #462806
09/08/09 04:35 PM
09/08/09 04:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Disconnect the shifter rod and place the Reverse lever all the way into gear by hand, if the switch closes the shifter adjustmrent is incorrect.
Re: Backup light engagement? [Re: John_Kunkel] #462807
09/22/09 10:42 PM
09/22/09 10:42 PM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
Finally got under and did this. Light does not come on in natural reverse position. Needs a little more, like .02.
My only thought is to get NOS switch. I know that the original switch had no problems, only these Mopar replacements. I will also check my other transmissions.
Question. Anyway to test whether a switch leaks?
Shawn 70 AAR
