Backup light engagement?
#462801
09/07/09 11:08 PM
09/07/09 11:08 PM
Posts: 289 Toronto, ON
ehbody
Toronto, ON
I replaced the backup switch on my 4speed Cuda. Reverse light on the dash only engages if I push the shifter in reverse a little more. Is this just a matter of adjusting the linkage rod?
Shawn
70 AAR
Re: Backup light engagement?
[Re: RapidRobert]
#462803
09/08/09 12:06 AM
09/08/09 12:06 AM
ehbody
Toronto, ON
Replaced because it was leaking, but it had the same problem before.
Shawn
70 AAR
[Re: ehbody]
#462804
09/08/09 12:14 AM
09/08/09 12:14 AM
RapidRobert
I am not familiar w sticks but is there any way to screw it in a bit more so the plunger will get depressed further.
[Re: RapidRobert]
#462805
09/08/09 12:42 PM
09/08/09 12:42 PM
ehbody
Toronto, ON
Nope. Tight up and a paper gasket. My original switch did not have this issue, but it broke, then I got MP replacement, and after 10years it leaked, now I got another MP replacement.
Shawn
70 AAR
[Re: ehbody]
#462806
09/08/09 04:35 PM
09/08/09 04:35 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Disconnect the shifter rod and place the Reverse lever all the way into gear by hand, if the switch closes the shifter adjustmrent is incorrect.
[Re: John_Kunkel]
#462807
09/22/09 10:42 PM
09/22/09 10:42 PM
ehbody
Toronto, ON
Finally got under and did this. Light does not come on in natural reverse position. Needs a little more, like .02. My only thought is to get NOS switch. I know that the original switch had no problems, only these Mopar replacements. I will also check my other transmissions. Question. Anyway to test whether a switch leaks?
Shawn
70 AAR
