Re: Which 4" crank for 340 build ?
[Re: quick77rt ]
#462406
09/07/09 07:41 PM
09/07/09 07:41 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I've owned a couple at the same time, a Callies Dragonslayer and a Scat Lightweight, I chose to build my engine using the Scat because it was lighter, both appeared to be excellent cranks and were delivered within spec, no problem, never used a K1 but hear good things. Using Carillo steel rods (which are pretty light) and Diamond Lightweight pistons my crank required no extra metal to balance it.
I am a believer in keeping the lower end as light as possible for reasons of longevity, one possible side benifit is a quicker reving engine/better 60 ft times, but I doubt it's a huge difference. Contact Ryan at Shady Dell, he knows about all there is about them, he can probably lead you the right way.
[Re: S/ST 3040]
#462412
09/07/09 09:16 PM
09/07/09 09:16 PM
Quicktree
I will NEVER buy another item with K-1 name on it.
you can't make a statement like that without telling us why?
[Re: S/ST 3040]
#462415
09/07/09 10:34 PM
09/07/09 10:34 PM
It has nothing to do with the crankshafts.
i talked with Tom over 2 years ago about 4.125 and 4.250 cranks. it's not like it's a new concept. i was also the guy that got the 360 main 4" cranks made. at the time i had a lot more than than 5 made. they came in on pallets. i believe i bought every 340/360 2.1 journal 4" crank they had available at the time. i wasn't privy to the conversation between Tom and BPE, but i do know that any time your looking for an exclusive deal, it usually takes more than 5 cranks, a lot more actually and you always want a signed contract. that's just good business. we've been very happy with the K-1 products and as far as i know, so have my customers. fortunately for all of us, we all have plenty of choices now for mopar crankshafts.
#462416
09/07/09 11:00 PM
09/07/09 11:00 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Dan........I have no intention of starting a pissing match with anybody here. I was privy to the conversations and the agreement. I hope you sell 40 Callies cranks this month.
[Re: S/ST 3040]
#462417
09/08/09 12:25 AM
09/08/09 12:25 AM
it's all good as far as i'm concerned, i hope i sell 40 callies cranks this month too.
[Re: ademon]
#462421
09/08/09 05:03 AM
09/08/09 05:03 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
i did knock the baffles upward,
Same here, I ran 1.6 Hughes with my stock heads with .592" lift in stock valve covers. They're now on my Edelbrocks with .633" lift.
If I were doing a 340 I would use a Callies Dragon Slayer. I have a K-1 in my 408, it checked out good.
