Which 4" crank for 340 build ? #462404
09/07/09 07:24 PM
09/07/09 07:24 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Taking my 68' 340 std bore block in to get sonic checked and see how the bores look this week and need to start ordering parts. This is going to be street/strip type build. I'm looking at a few different forged cranks. K1 heavy but cheaper, Scat and Callies which are lighter but more $$ Is 10-12 lbs savings worth the extra $$$ I plan on going with scat 4340 I beam rods.
Re: Which 4" crank for 340 build ? [Re: Beebuzzn] #462405
09/07/09 07:29 PM
09/07/09 07:29 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Make sure your not going to have to spend $$$ on getting the lighter weight crank balanced.
The K1 and ones like it (weight) ended up in an internal balance with no $$$$ on balance weight.
Re: Which 4" crank for 340 build ? [Re: quick77rt ] #462406
09/07/09 07:41 PM
09/07/09 07:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I've owned a couple at the same time, a Callies Dragonslayer and a Scat Lightweight, I chose to build my engine using the Scat because it was lighter, both appeared to be excellent cranks and were delivered within spec, no problem, never used a K1 but hear good things. Using Carillo steel rods (which are pretty light) and Diamond Lightweight pistons my crank required no extra metal to balance it.
I am a believer in keeping the lower end as light as possible for reasons of longevity, one possible side benifit is a quicker reving engine/better 60 ft times, but I doubt it's a huge difference. Contact Ryan at Shady Dell, he knows about all there is about them, he can probably lead you the right way.
Re: Which 4" crank for 340 build ? [Re: ScottSmith_Harms] #462407
09/07/09 08:02 PM
09/07/09 08:02 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Thanks for the info and I plan on contacting Ryan J and a few others as I plan on running some iron x heads that will need a max effort to make them flow.
Re: Which 4" crank for 340 build ? [Re: Beebuzzn] #462408
09/07/09 08:19 PM
09/07/09 08:19 PM
AndyF Offline
AndyF  Offline
Callies also has a 4.250 crank in stock, K1 has 4.125 cranks and Hughes has a 4.180 crank. Most of those kits will work with Chevy 6.125 or 6.200 connecting rods but the Hughes crank uses Quad 4 rod bearings.
So a lot more choices than just the usual 4.00 inch crank.
Re: Which 4" crank for 340 build ? [Re: AndyF] #462409
09/07/09 08:26 PM
09/07/09 08:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, my scat started life as a 4.0 but it was further customized and stroked to 4.125 to help me get to 426 cid. Back then the off the shelf over 4.0 cranks weren't around yet.
Re: Which 4" crank for 340 build ? [Re: Beebuzzn] #462410
09/07/09 08:36 PM
09/07/09 08:36 PM
SoCal
Brian Hafliger Offline
SoCal
That's what we do alot of...Scat 4340 4" cranks and I beam rods. If you have the money the liteweight crank is nice, but the std. weight will work and most likely will not be noticeable in a street/strip build.
I also use KB forged pistons, total bobweight is around 1750-1760g.
You will be very happy with this setup!!
Brian Hafliger
Re: Which 4" crank for 340 build ? [Re: AndyF] #462411
09/07/09 08:37 PM
09/07/09 08:37 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I will NEVER buy another item with K-1 name on it.
Re: Which 4" crank for 340 build ? [Re: S/ST 3040] #462412
09/07/09 09:16 PM
09/07/09 09:16 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you can't make a statement like that without telling us why?
Re: Which 4" crank for 340 build ? [Re: S/ST 3040] #462413
09/07/09 09:17 PM
09/07/09 09:17 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Please explain.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: Which 4" crank for 340 build ? [Re: Cudahlr] #462414
09/07/09 09:56 PM
09/07/09 09:56 PM
S/ST 3040 Offline
S/ST 3040  Offline
It has nothing to do with the crankshafts.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Which 4" crank for 340 build ? [Re: S/ST 3040] #462415
09/07/09 10:34 PM
09/07/09 10:34 PM
i talked with Tom over 2 years ago about 4.125 and 4.250 cranks. it's not like it's a new concept. i was also the guy that got the 360 main 4" cranks made. at the time i had a lot more than than 5 made. they came in on pallets. i believe i bought every 340/360 2.1 journal 4" crank they had available at the time.
i wasn't privy to the conversation between Tom and BPE, but i do know that any time your looking for an exclusive deal, it usually takes more than 5 cranks, a lot more actually and you always want a signed contract. that's just good business.
we've been very happy with the K-1 products and as far as i know, so have my customers. fortunately for all of us, we all have plenty of choices now for mopar crankshafts.
Re: Which 4" crank for 340 build ? #462416
09/07/09 11:00 PM
09/07/09 11:00 PM
S/ST 3040 Offline
S/ST 3040  Offline
Dan........I have no intention of starting a pissing match with anybody
here. I was privy to the conversations and the agreement.
I hope you sell 40 Callies cranks this month.
Re: Which 4" crank for 340 build ? [Re: S/ST 3040] #462417
09/08/09 12:25 AM
09/08/09 12:25 AM
it's all good as far as i'm concerned,
i hope i sell 40 callies cranks this month too.
Re: Which 4" crank for 340 build ? [Re: Brian Hafliger] #462418
09/08/09 12:36 AM
09/08/09 12:36 AM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
I like the idea of going bigger than 4" stroke but since I will be using the old x heads with a max port job I still won't be able to maximize what a 4"stroke is capable of. I am looking at Diamond pistons around 9.5/1 and a hyd cam. This build up will be going in a 70 challenger 4 spd with 3.55 gears. Cam suggestions ? I have a comp xe284h and maybe use some 1.6 rockers ? I want to use my stock valve covers and I know that will limit my choice on the rockers.
Re: Which 4" crank for 340 build ? [Re: Beebuzzn] #462419
09/08/09 01:18 AM
09/08/09 01:18 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There's acouple ways to deal with rocker clearance in stock valve covers. The baffles can be removed and replaced with smaller/shallower ones, and you can use double VC gaskets to gain some clearance.
Re: Which 4" crank for 340 build ? [Re: ScottSmith_Harms] #462420
09/08/09 01:37 AM
09/08/09 01:37 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i had a post way back about the stock 340 v/c clearing the comp pro magnum rockers i have, another member said his cleared the comps without any mods, i did knock the baffles upward, i'm going to install them in a couple weeks, get the moroso silicon gaskets.
Re: Which 4" crank for 340 build ? [Re: ademon] #462421
09/08/09 05:03 AM
09/08/09 05:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Same here, I ran 1.6 Hughes with my stock heads with .592" lift in stock valve covers. They're now on my Edelbrocks with .633" lift.
If I were doing a 340 I would use a Callies Dragon Slayer. I have a K-1 in my 408, it checked out good.
Re: Which 4" crank for 340 build ? [Re: justinp61] #462422
09/08/09 08:27 AM
09/08/09 08:27 AM
Lehigh Acres, Florida
rickstershemi Offline
My choice would be "Compstar"
Rickster
Re: Which 4" crank for 340 build ? [Re: rickstershemi] #462423
09/08/09 08:42 AM
09/08/09 08:42 AM
S/ST 3040 Offline
S/ST 3040  Offline
The only Compstar cranks I see they are currently
making for Mopar is for the 5.7 and 6.1 Hemi.
