Another electronic ignition problem #461990
09/07/09 04:49 PM
09/07/09 04:49 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Switching from a chrysler typr electronic ignition to a pro-comp setup and get zero spark at the coil. All wire connections are correct. Changed coil...no difference. Connected the 12 volt red to the battery...neg to battery...other pickup red to ignition key on...distributor wires proper...orange wire to the coil and black to coil..blue ignition wire to coil...hooked another distributor to system and all's it does is make electronic noises when turned...still no spark at coil wire...going to change the box tomorrow...Keyed voltage on pickup wire is around 10.6 volts....goes to coil...is this proper?? also connected wires that were connected to ballast...as it's no longer a player. do have over 12 volts to power the box from the battery..all wires have good continuity..Thanks in advnce to any/all help...Thanks moparts
Re: Another electronic ignition problem [Re: terzmo] #461991
09/07/09 04:57 PM
09/07/09 04:57 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I believe I have read elsewhere that The Procomp electronics are of poor quality. I read that they were made in China. Read here:
http://www.chevytalk.org/fusionbb/showtopic.php?tid/168575/
Re: Another electronic ignition problem [Re: mopars4ever] #461992
09/07/09 07:17 PM
09/07/09 07:17 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Thanks...I believe they are imported also...BUT...have bought 6 or so sets and did have 1 problem with a coil..they replaced with no problems...good people to work with
Re: Another electronic ignition problem [Re: terzmo] #461993
09/07/09 07:21 PM
09/07/09 07:21 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
What's wrong with factory Chrysler?
Re: Another electronic ignition problem [Re: BulletBob] #461994
09/08/09 07:40 AM
09/08/09 07:40 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
better..hotter spark..rev limiter....why does anyone go to MSD vs stock chrysler? Did You ask that?
Re: Another electronic ignition problem [Re: terzmo] #461995
09/08/09 08:35 AM
09/08/09 08:35 AM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
If you are still using the Chrysler distributor after installing the MSD and are not using vaccumn advance you need to weld the 2 plates together to eliminate high rpm miss. Chrysler dist are the worst. By you doing this they are as good as any other. I have done it on my cars and they run great.
Re: Another electronic ignition problem [Re: Cuda67] #461996
09/08/09 04:53 PM
09/08/09 04:53 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
The setup included the billet distributor...I had an extra wire on the coil and removed it...spark to distributor was so nice , a person could weld with it...car fired and is running nice..now on to the other 15 or 20 issues.....lol
